Magnecor's installed
Old 09 Jan 2005, 06:29 pm
Default Magnecor's installed
Put the Magnecor wires in today and was very happy with the result. Throttle response is most excellent and the engine purred strongly throughout the rpm range. Much better aftermarket wires whether Magnecor, Crane or MDS are a must for the serious and not as serious enthusiasts. Also, seeing first hand how the hyperground improves throttle response and smoother running, these two mods together go hand in hand and will put a big smile on your face
Old 09 Jan 2005, 06:59 pm
What size Magnecor wires did you use and do you think a Screamin Demon Hi-Power Coil Pack would be appropriate, especially for a STAGE 1 car? What kind of spark plugs are you using and what is the gap setting? Thanks.
Old 09 Jan 2005, 08:15 pm
The wires are 8.5mm.....I have heard ASE certified mechanics on all of the forums state that the factory coil puts out more than enough juice. It would be a waste of money.....I am using the factory Copper Plus plugs and they are gapped at .040.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 09 Jan 2005, 09:21 pm
Thanks, Mean Green.
Roof Rack "factory installed" for GT KevinM Exterior Accessories Forum 12 27 Jul 2009 02:02 pm
Psi-Fi PowerPaq installed. WOW!!! ksquared11 Turbo Performance 17 13 Jan 2008 04:26 pm
Pillar Pod and Gauges installed Mean Green Turbo Performance 25 12 Nov 2004 01:38 am
Stage 1 Installed Question Kirby Stage Turbo Kits 6 19 Aug 2003 03:51 pm
TurboXS RFL BOV and AGPTurbo BOP installed!! RobGT Turbo Performance 1 23 Jun 2003 05:38 pm
