Is there some secret code to removing the oil filter on the GT? 3,100 miles on mine, and time to cahnge the oil. I drained it then went to remove the filter.
I have a filter tool, but can't get it to fit between the filter and whatever pipe it is that is next to it. I then tried a strap tool. Not only will it not budge the filter, but collapsed it a bit. Any help will be appreciated. Jumpin' Joe Onyx Green GT |
The first one's always a bi...! Try the strap but get in closer to the gasket end even if you can only get a quarter turn to break it loose . Failing that its gonna be drive a screw driver though it to get it to turn but last resort 'cuz if that fails you gonna need to get towed probably !
'03 Electric Blue 5 speed GT, bassani axle back single exhaust,addco oversize front,rear sways,wildfire strut bar,color-matched rear muds,xenon sides,mirrors,b&c pillars,both interior consoles,b&m sport shifter Edited by - flashbk2 on 04/13/2003 11:45:23 |
I took one of those metal loop wrenches and removed the pin from one side, then snaked it around the filter and put the pin back in place. It still took about 5 or 6 hard turns before the filter came off.
Factory filters are paper thin to begin with, so you gotta make sure you dont just twist the filter without twisting the screw. I use Mobil1 oil along with the Mobil1 filter (M1-209). Matt 2003 GT Cruiser |
Thanks. If it doesn't work, get a bigger hammer is my motto!!
I have two sizes of strap wrenches - used the smaller on the first time. Got the bigger one, and after much grunting and groaning was able to break it loose. Thanks Jumpin' Joe Onyx Green GT |
ya I just did my first oil change and had the same thing.. I got the strap one because the other one didnt fit.. you can turn the strap thing sidways and get it in there.. then I got the fram one with the grip on it so you can just take it off with your hand next time..
the oil wrench will fit ,come from the top and it will go right on.
jim |
What was the pn of the Fram filter that you used? macster Don't help me Help the bear |
Had a 89 cherokee once. The first oil change was a nightmare. Totaly destroyed the filter taking it off. Chrysler is known for this as I found out later. Took the GT to a lube place for it's first change. Let them do the cusing and knuckle banging.
I used a strap filter wrench and it came right off
Used a large wrench and dad <img src=icon_smile_big.gif border=0 align=middle>
| Cabin air filter | AlmondTurbo | General PT Cruiser Discussions | 36 | 07 Sep 2011 07:58 am |
| Whats up with factory oil filter | yotehunter | General PT Cruiser Discussions | 10 | 09 May 2005 08:28 am |
| Compare/contrast Air Filter Elements | andym | Tech & Performance Forum | 7 | 02 Jul 2004 11:02 am |
| Watch out K&N! | azptcruiser | Non-PT Discussions | 3 | 01 Apr 2004 11:55 am |
| K&N filter oil on BTG filter? | Punch | Turbo Performance | 1 | 15 Oct 2003 11:55 pm |
