PT Cruiser Forum Car Videos
Custom Wheels
GT EGT/Boost Pod Pics
  #11 (permalink)
Old 21 Apr 2003, 11:41 am
03baggedturbo 03baggedturbo is offline
Send a message via AIM to 03baggedturbo
good work ... I am glad that you guys are out there doing some very cool new things to make these cars come up.. will be nice to see how fast and reliable they can get to..
  #12 (permalink)
Old 23 Apr 2003, 03:34 pm
RobGT RobGT is offline
Have the lunar gauges on order ....is an additional "bung" needed to mount the EGT probe?? Also.. did they end up mounting the probe like ExhaustDepot's or elsewhere?
Thanks!
Rob
Click to see my GT!!
  #13 (permalink)
Old 23 Apr 2003, 03:51 pm
Ripster Ripster is offline
All parts are included with the lunar series. The ones here look stock, installed before the turbo. That type of install would be time consuming as you would need to remove the turbo and probably intake to clean out any filings from installation. If the weather holds I will crawl under the GT on ramps and get a picture post-turbo in the exhaust pipe after the turbo. The temperature will be cooler after the turbo, no one has been able to get me a exact number, but most agree in the area of 2-300 degrees cooler post turbo, still good enough to see over 1000 degrees and give you a good idea of temperature in your turbo. With the lunar you drill a hole, then use the self tapping bolt, that the egt then screws into.
  #14 (permalink)
Old 23 Apr 2003, 06:49 pm
Perfect..Thanks! Dont think I want to remove the turbo...will prob put mine after... Looks like next week at this point.
Would love to see pics!
Thanks again!!
Rob
  #15 (permalink)
Old 23 Apr 2003, 06:51 pm
Hey Ripster...you wouldnt happen to be in NY??!! Need a recommendation for a good Shop to install!!!
Rob
  #16 (permalink)
Old 23 Apr 2003, 07:41 pm
mich_13 mich_13 is offline
RobGT - Off the subject but was looking at your Car Pics. How did you do the neon behind the grill? Really cool ! ! ! <img src=icon_smile_tongue.gif border=0 align=middle>
Inferno Red GT Auto-Stick - Chrome Grill, Chrome Rear Mud Guards, Chrome Wheels, Magnetic Flames
  #17 (permalink)
Old 23 Apr 2003, 07:52 pm
Thanks Mich - I had a 8" Blue neon tube lying around after I ripped apart my bandpass sub box from my old vehicle (used one 12" sub for the PT)...just used wire ties to attach it to the bracket behind the grille, and tapped into the fog light wire for power - with one of those piggyback crimp connections...turns on/off with the fogs.
Its subtle..but check some of these out:
http://ptenthusiasts.org/PTForums/sh...threadid=32327
Rob
  #18 (permalink)
Old 23 Apr 2003, 07:53 pm
grrr..i cant post links...<img src=icon_smile_dead.gif border=0 align=middle>
Copy and paste:
Rob
  #19 (permalink)
Old 27 Apr 2003, 04:51 pm
As promised here is a picture of the EGT probe. You can see the self-tapping hollow bolt that is screwed into a hole that is drilled into the exhaust, just after the special collar before the exhaust connects to the cast housing of the turbo. Do not drill the special collar, I believe it is layered with the ability to move with the engine torque. Once drilled and tapped, you screw in the EGT and route the wires. (Autometer Lunar Series EGT Probe)
Also using the Autometer pod, I used the Dark Slate Grey paint, which means that you will need to spray the opposite piller. They make an exact match for the Turbo trim. We like the dark lines going to the roof, which will be on both sides.
There is not a visibility problem in any direction with a pod installation in my opinion. The lunar series is a match at night with illumination color also.
  #20 (permalink)
Old 27 Apr 2003, 04:56 pm
Exhaust Depot:
I am unable to see if your turbo EGT has markings on it, but does it have a caution area or red area that suggests where you might be creating more heat than you should? Yours also looks stock as if it came with the car, installed from factory, correct? thanks
vB code is On
Need Help with pics Crewzin???? turbomangt Non-PT Discussions 11 03 Aug 2006 11:10 am
my newest mods. NEW DAYLIGHT PICS CruiserDan Exterior Accessories Forum 10 27 Oct 2005 08:00 pm
Pics of my tail lights on clean GT Red GT Exterior Accessories Forum 11 16 Mar 2005 01:06 am
Cruisin' the Blue Ridge Parkway pics FloweryBranchCruiser General PT Cruiser Discussions 7 28 Sep 2004 12:25 am
TURBOMANGT PICS!!!! turbomangt General PT Cruiser Discussions 19 22 Jul 2003 01:38 pm
  Credit Card | Credit Counseling | Credit Cards | Remortgaging | Mortgage Calculator
