Gauge light install question
Old 19 Apr 2003, 10:38 pm
Default Gauge light install question
I have installed my boost and air/fuel gauges, but am having a problem finding a dash light source so that the gauge lights can be controlled like the dash lights. I purchased a circuit tester and probed the wires off the back of the switch in the column, but could't seem to find a wire that reacted with the dimmer control. Anyone have a color code for the wire or a photo of where you found a spot to splice into? Any help would be greatly appreciated.
PT-Dave
2003 Cranberry Turbo GT
Old 20 Apr 2003, 12:32 am
I used the Dimm Control Wire that goes to the radio for my gauges, I have an aftermarket radio with a wire harness adapter, so I just spliced off that.
It's the Orange wire on the factory harness to the radio, position 3 on the 22 Pin connector.
Matt
2003 GT Cruiser
Edited by - Chipmunk on 04/19/2003 23:32:52
Old 20 Apr 2003, 10:15 am
Thanks for your prompt response. I don't have a manual (Oops!) so I really don't know where to find or gain access to the radio connector. I have dropped the panel down below the column and can see several connectors with tons of wires. I have poked dozens, but still can't seem to find the right one. Do you happen to have a photo of the proper connector, or will I have to pull the dash cover to get to it?
It's been a really long time since I have done this sort of thing. I remember being able to easily contort myself under the dash to gain access to almost anything. Now, at 56 and nearly 240 pounds it ain't so easy anymore!
PT-Dave
Old 20 Apr 2003, 09:03 pm
Problem solved! It turns out that there is an orange wire going up the pillar right behind the post cover that I removed. It is controlled by the dash light dimmer circuit. I suppose if I had had a manual, I would have figured it our sooner.
PT-Dave
Old 20 Apr 2003, 09:24 pm
PT Dave...my gauges coming this week...thanks for the tip!!!
By the way...did u need an O2 sensor for your a/f gauge??
Rob
Old 21 Apr 2003, 09:34 pm
RobGT,
Yes, I had to order one from Summit Racing for 89.95 plus handling. The part number is ATM-2244.
Here is the link: http://store.summitracing.com/defaul...&part=atm-2244
PT-Dave
Old 22 Apr 2003, 11:19 am
Thanks Dave...maybe ill add the A/F in the future...I have Boost/Vac and a Pyrometer on the way...spent more $$$ on a dual boost controller so i had to sacrifice a gauge!
Great to hear it worked for you tho....good luck!!
Rob
Click to see my GT!!
Old 20 Sep 2003, 08:17 pm
quote:Originally posted by PT-Dave
RobGT,
PT-Dave
where does the new sensor end up being installed? any pictures of it? etc...
Punch
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Mopar Boost Gauge install question ksquared11 General Turbo Discussions 1 19 May 2004 02:05 am
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
Install of Water Temp Gauge jramosGT Turbo Performance 6 18 Apr 2003 03:35 am
