200 TO SPEND, WHAT SHOULD I GET??
  #11 (permalink)
Old 27 Mar 2005, 05:00 pm
I am going to have to disagree a little. Everything will work with the stock plumbing as long as the boost is not pushed up too high. Uner 18 or so psi and the loss through stock plumbing is minimal. Just wanted to put in my 2 cents worth and problably will get back channge! [:0]
quote:Originally posted by Topless in Cali
I'd agree on the UCP. Then you'll be able to get every bit of boost out of s1. The wga and boost controller really won't work as effectively w/o UCP.
  #12 (permalink)
Old 27 Mar 2005, 05:55 pm
Send a message via AIM to AZ_IceMan
I agree with you on that aspect as far as just having stage one, but I push as much as 20-22psi and if I didn't have Adam's UCP, I'd have some "issues" to say the least about my boost.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
  #13 (permalink)
Old 27 Mar 2005, 10:26 pm
Even if you don't raise the boost much, you will feel a difference with an UCP. I did it before installing stage 1 and felt a difference right away!
  #14 (permalink)
Old 28 Mar 2005, 04:24 am
Here's one of your pennies back I noticed you don't have an aftermarket ucp so you are not aware of the difference. There is a big difference between factory ucp and the VAK ucp. Last year I had to take off the VAK ucp and reinstall the factory one for a little while. It was really a bummer. The car did not have the pull that the VAK ucp gave it. It was depressing to get on my GT. When I reinstalled the VAK ucp I was on cloud 9. So the loss with the factory ucp is much larger than you think. You should get the VAK ucp as well [?]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Bush or Kerry TaylorMade Non-PT Discussions 172 23 Sep 2005 02:26 pm
$5k to spend... but with restrictions emr131 Turbo Performance 10 14 Jul 2005 08:41 pm
Before i spend the big bucks. technobear Tech & Performance Forum 9 11 Jul 2004 02:22 am
How should I spend my money!!?? yobiebs General Turbo Discussions 5 09 Jul 2003 03:06 am
Prison or Work? You decide... Gary04GT Non-PT Discussions 1 29 Jun 2003 04:09 pm
