Exhaust....
Old 07 May 2005, 06:08 pm
Send a message via AIM to hangtym3
Default Exhaust....
Hello, I am wondering about the different sizes of exhaust, I was planning to get the BTG Duals Cat/Back http://www.pttuning.com/performanceP...BTG-Duals.html but they are only 2 1/4"....I heard that if you will need a bigger size of exhaust to reach higher hp...if thats so...1)how much hp can these 2 1/4" let out? 2)If you have any better exhaust feel free to put in ur 2 cents
Old 07 May 2005, 07:48 pm
Mopar "recommends" a 2 1/2" exhaust with the Stage 1 kit and was saying it was required with the ill fated Stage 2 kit that will never see the light of day for the PT. So the 2 1/4" is good for something like 250 hp. From 250-300 a 2 1/2" is needed. Above 300 you should probably be looking at 3".
Old 07 May 2005, 11:34 pm
Ok...how about these... http://www.haynesspeedshop.com/Store...&cat=37&page=1
Noob w/ Cars....dont be mad \'03 Onyx Green GT Autostick
Old 10 May 2005, 01:19 am
Send a message via AIM to TurboCruiser13
Save yourself about 200 bucks off that mopar one and go take it to a muffler shop. I got mine done for 210 includes 2.5" all the way back, magnaflow SS resonator then splits over the axle and goes to 2.25" to the back. About the same loudness as the BTG just a slightly different sound.
Old 10 May 2005, 02:59 am
Pays your money picks your poison. the MOPAR/Borlas are quieter and fit like a glove the customs can be real expensive or real cheap depending on installer and products used. Most are a lot louder than MOPAR and dont make more power. Some like the extra noise! Some wipe out the spare tire carrier some dont. Some make a droning noise at certain speeds the MOPAR dont. If you dont add engine mods the MOPAR and others are just for looks and sounds.
Old 10 May 2005, 03:21 am
If you get a custom job make sure they do mandrel bends and not crimped ones. Most exhaust shops do not do mandrel bends, only some do. Crimped bends impede exhaust flow, mandrel bends do not.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 May 2005, 08:46 am
My $.02.
If you want 2.5, better go for a bigger cat or you're choked by that anyway.
The BTGs, while "only" 2.25, are true flow-thru - you can see clear thru each piece. There are 3 sections that are larger with internal perforations (resonators) - but inside diameter stays 2.25 - can't flow much better than that.
IMHO they are a better design than the Borla, (or Bassani, which I had on my '02) which dumps into a muffler and sends a pipe "back" to passenger side. The BTG has a "Y" pipe splitter - some others come close, but have more of a "T".
The downside is that the BTG is pretty loud - but it's a Ballsy loud, deep, not Ricer. Look carefully at the layout of the different exhausts - the BTG makes the most sense to me.
(Cheapest I found was PTWarehouse - it doesn't say it's BTG, but it is).
THE PRECEEDING IS MY OPINION. Exhaust loyalty is nearly like tire loyalties...
Old 11 May 2005, 06:43 pm
Go to a muffler shop. I paid 325 for mine. 3" all the way back with a flowmaster. He used manderal pieces around the axle. Also, single 3 inch flows more than a dual 2inch. Sounds weird but its true. You can save money going to a muffler shop instead. Now I need to go back to the muffler shop to modify mine. I put eibachs on last week to lover the car. Now when I go over little bumps my exaust hit panhard bar on the axle. So if you go custom lower it first then do exaust.
2003 PT TURBO, STAGE 1, 3IN\" CAT BACK W/ FLOWMASTER, CUSTOM CAI, EIABACH SPRINGS, GLOVE BOX MOUNTED BOOST GAUGE
Old 12 May 2005, 06:18 pm
another alternative is the TruBendz systems
http://www.trubendz.com/home.asp?pro...e=productIndex
or the HeartThrob systems at www.JCWhitney.com
Old 15 May 2005, 03:57 pm
I have had the BTG catback for a little over a year now and love them. A little expensive at first but, stainless steel, will probably out live me.
Marty from MD
Black GT 03, BTG cat/back duals, rocket taillights, BTG shock strut bar, & Blane hood struts
Need Exhaust Advise NkBkGt Exterior & Interior Styling 11 25 Aug 2003 10:36 pm
2.25" or 2.50" Exhaust PuterTater Cruiser Tech & Performance Forum 2 25 Sep 2002 10:57 am
