PT Cruiser Forum Car Videos
Car Rims
aftermarquet wga question
Old 10 May 2005, 06:54 pm
steve smith steve smith is offline
Default aftermarquet wga question
if i install an aftermaquet wga i just want to know if i ave to reset the ecu every 300km
Old 11 May 2005, 03:31 am
Mean Green Mean Green is offline
Why would you? I have an AGP wga and I don't reset the ecu every so many miles.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 11 May 2005, 01:44 pm
dfunkdj dfunkdj is offline
Send a message via AIM to dfunkdj
Yeah why would have to reset the ECU ???? I have a AGP WGA and a turbo xs MBC and havent touched the computer in 20,000 miles
Don
<font color=\"orange\"><b>2003 Dream Cruiser II
Stage 1, Greddy blow off valve, AGP WGA, Custom open dual exhaust, Denso plugs, Xtremeboost upcharge pipe, AMX intake pipe, Ramair hoods hood, Apc ground effects kit, lowerd 3\", Turbo xs MBC, auto meter double gauge pod, and 2 more gauge mountd on sterring wheel {oil psi and temp, boost, water temp}
apc 2nd gen tail lights, more to come soon
Tampabay Pt Cruisers</b></font id=\"orange\">
Old 11 May 2005, 02:38 pm
DMW DMW is offline
Can a WGA be used in place of Stage 1? Or do you guys just use that on top of stage 1 to get a little extra boost?
-Dave
Old 11 May 2005, 06:06 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
You can't use it in place of Stage 1 because you'll get an overboost code and a check engine light, plus your ecu will pull and retard the timing and you'll lose horsepower. We use it to raise boost after stage 1 for and added kick in the pants. [8)]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 12 May 2005, 02:27 am
Yeah, and what a kick in the pants!!!!!!
Old 12 May 2005, 01:22 pm
Yeah a nother kick just like stage 1
speed speed speed
Old 13 Jun 2005, 08:57 pm
SuGamer SuGamer is offline
Techincally you can. You would need to clamp the MAP sensor to the voltage that matches, say 10.5psi, and do the EDTIP mod. But beware! Don't attempt this unless you have a wideband Air-Fuel Ratio gauge installed because if you go high in boost you will be leaning out the mixture and can burn holes in your pistons if the mixture is to lean! [:0][:0] Still not worth the risk. Install Stage 1 first.
vB code is On
Mirror was broken, Question? stirfry General PT Cruiser Discussions 6 14 Sep 2005 11:30 pm
Rear Shelf Question technobear Interior Accessories Forum 23 13 Aug 2005 12:23 pm
Question: Wheels and PT Wheel Wells PTGT_Boy Turbo Wheels/Suspension/Handling 42 13 Sep 2004 11:46 pm
Question and an Idea on Speakers nozzano22 Sound and Security Forum 5 21 Jul 2004 11:38 am
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
  Problem Mortgage | Hollywood Gossip | Loans | Bad Credit Mortgages | Search Engine Marketing
