Will the Short Throws work on the GT's
Old 25 Apr 2003, 11:01 pm
Default Will the Short Throws work on the GT's
Has anyone tried a short throw shifter such as the Hurst Quick Shift on a GT? I can only find ones designed for the non-turbos that do not have the Getrag, which has reverse on the left. Flashback said he tried a B&M for a non-turbo and it worked fine, but I would like to swap the bushings out too. I dont know that much about it, should the different tranny & shift pattern keep the Hurst short throws for non-turbos from working?
03 Turbo Inferno.
Dave
Old 26 Apr 2003, 10:21 am
Only thing I know about the bushings is that the ones on the tranny I would assume to be different . Let us know who's bushings work ,please both on tranny and under console !
'03 Electric Blue 5 speed GT, bassani axle back single exhaust,addco oversize front,rear sways,wildfire strut bar,color-matched rear muds,xenon sides,mirrors,b&c pillars,both interior consoles,b&m sport shifter,hallman boost controller,ghetto intake
Old 27 Apr 2003, 06:57 pm
Not asked but here is an answer. I bought a "short throw" lever that attached to the tranny and shortens the pivot point there as the maker assured me it would work on the GT. It doesn't so if someone suggests buying one, don't waste you $50.
Old 28 Apr 2003, 08:33 am
Do you remember what brand/model did not work for you Cal Cruzer?
Dave
Old 28 Apr 2003, 02:38 pm
This is the lever that attaches to the shaft that comes out of the trans, not the shift lever in the car. It is sold by Modern Performance in Houston. I just spoke to them and they are taking it back. I don't think they were aware that the turbo had a different trans.
Old 03 Jun 2003, 11:44 pm
Does anyone have a detailed pic of the tranny end of the shifter cables? I'd like to either verify that my shifter bushings work on the turbo version OR figure out what needs to be done to get some to work.
JeffB#2
\'95 Ply Neon ACR sedan Nitro Yellow-green
14.11 @ 98 all motor SOHC
http://www.scecnet.net/~neonneon/buyparts.html
Old 04 Jun 2003, 08:43 am
Jeff it's pretty difficult to get a pic . Even with the airbox removed as in my setup you'd have to pull the pdc and get it out of the way in order to get a detailed pic. I was gonna try to get you apic but it may take some time.
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 04 Jun 2003, 09:57 am
Jeff here's the best I can do ! Hopefully it'll help.
Old 04 Jun 2003, 06:51 pm
Flash. You better hit that rascal up with some soap and water[8]...
Yuk[:0]
j/k
Old 04 Jun 2003, 07:51 pm
It'll all be "simple- greened " right before CFIII . No use getting it clean before then the way it's been raining here! I'd just be doing it all over again,lol!
Detail work. check list turbomangt The Detail Shop 9 22 Jun 2006 08:34 am
Will stage 2 wastegate off a SRT-4 work. nastyvr6 Turbo Performance 5 23 Jul 2005 05:17 am
The work of Steven Wright Jimbo Non-PT Discussions 5 08 Feb 2005 01:53 pm
Short Antenna Indynick General PT Cruiser Discussions 11 25 Jul 2003 05:06 pm
Prison or Work? You decide... Gary04GT Non-PT Discussions 1 29 Jun 2003 04:09 pm
