Will "simple mods" really increase GT horsepower?
  #11 (permalink)
Old 30 Apr 2003, 09:02 pm
yep.....BIG and straight!!!
My Cruiser is slow. I love the law.
  #12 (permalink)
Old 01 May 2003, 12:08 am
quote:If you are just going to drive the car, the exhaust is fine. However if you plan on modding the car, yes the exhaust is restrictive.Remember that this is a turbo car and turbos like big piping
I have heard stories about boost pressure dropping with a larger diameter pipe--2.5 to 3 inches. Think I'd be a little leery about sizing up--would be concerned about problems (possibly a decrease in turbo performance) and voiding the engine warranty. Is my understanding correct or is "bigger piping better for the turbo engine"??? [:I] [:I]
  #13 (permalink)
Old 01 May 2003, 07:38 pm
You will lose some backpressure with a larger diameter pipe. You will notice this as a SMALL loss in low end torque. The increased mid to top end power will more than make up for this. Boost will not be negatively affected by this, if anything it allows you to run higher levels of boost more efficiently. That means that increasing the boost on a car with upgraded exhaust will yield higher hp increases than a car with stock exhaust.Why? Because boost is air that the engine has to push out through the piping. The bigger the piping, the less work the engine has to put into pushing it out, and the more power is transfered to the wheels. Let me put it this way: lets say you are out playing sports. Would you rather breath through a straw, or through a piece of tubing? Could you breath through the straw? Probably, but could you run as fast and as far as if you were breathing through the piece of tubing? I dont think so.The same is true for engines. So to answer your question: Bigger is Better.
Mike
90 Eagle Talon Tsi AWD - 300 Hp -K&N, 16g turbo, JE pistons, 3in Turbo back exhaust, mild port&polish
03 PT Cruiser GT - 215 Hp-Airbox and Intake pipe silencers removed
Intake mod that increases horsepower AND mpg! Jeff V General PT Cruiser Discussions 18 06 Dec 2005 11:41 am
Starkie's car...mods...pics (56K beware) starkie Non-PT Discussions 8 17 Apr 2004 12:12 pm
What more can I do to increase HP? alceryes General Turbo Discussions 26 31 Mar 2004 09:57 pm
HP increase With Diferent Items Ian-PT-GT Turbo Performance 22 29 Jul 2003 11:39 pm
Cost Efficient Mod's That Won't Void Warrenty strangelove Turbo Performance 58 19 Apr 2003 06:28 am
