Waste gate mod
Old 30 Apr 2003, 03:48 pm
Default Waste gate mod
I was reading on on of the srt4 site that one of the members put a spring on the wastegate actuator arm this helped to holle the high stock boost levels for a longer period. Now knowing that the spring in our stock WG is very week inside this causes it to start opening with oly 4 PSI. I can see how this would work but would this cause addition turbo lag?
Old 30 Apr 2003, 07:32 pm
No, turbo lag is not a function of the wastegate. It is more a function of turbo size and intake volume. You better have a good selection of springs and be willing to do a lot of experimentation to use this method of controlling boost. With the wrong spring you could easily blow an engine. Better to do as others here have done and use a bleed valve to control it. Check out the posts on the subject.
Old 06 Apr 2011, 02:42 pm
Default Re: Waste gate mod
Could someone post the size bleed valve needed and also tell me where exactly the wastegate is located?
Old 06 Apr 2011, 03:54 pm
Do either of you have a boost gauge cause without one you can easily blow your motor? For one thing, I wouldn't do such a ghetto mod as the spring mod. I'd get a real adjustable wastegate. Raising the boost is not just turning it up. You may need supporting mods depending on what you want. I've seen golfball size holes blown in a block from someone making poor choices with boost.
Old 06 Apr 2011, 03:57 pm
Please look in the upper left corner for the date posted. You both are posting to a 2003 posting.
Old 06 Apr 2011, 04:12 pm
Chromenut's Avatar
NO BOOST GAUGE = CANNONADED MOTOR!
...if I only had a brain...
I would need my own forum just to list my mods!!!
Remember, a PT Cruiser is not just a car, it's a way of life!
LAUS DEO SEMPER
Old 06 Apr 2011, 04:15 pm
Actually I'm batting .500. One from '03 and one from today.
Old 06 Apr 2011, 05:21 pm
I was just continuing a thread instead of starting a new one... Yes I have a boost gauge that I can hook up.
Can anyone post a link to a diagram of the turbo and wastegate setup?
Also, what type of bleeder valve have people been using? I have used a bleeder valve in the past on previous FI cars...
Thanks for the help
Old 06 Apr 2011, 09:16 pm
xwing777's Avatar
2004 Almond GT with autostick -Current Mods: lots
2006 Electric blue NA auto- Just starting to mod it!
Old 07 Apr 2011, 12:13 pm
So this is the wastegate circled in red correct? Where is the line to put the bleedervalve in? I don't see it or I am blind... What size is the line (or size bleeder do I get?)
Tail Gate Displays? kevinl1058 General PT Cruiser Discussions 22 18 Jul 2005 04:25 pm
lift gate latch. ajtug Classifieds: For Sale/Trade 0 24 Sep 2004 04:06 am
Turbochargers Waste Gate Install LAF Turbo Performance 3 23 Jun 2004 02:08 pm
Waste Gate Replacement ? LAF Turbo Performance 7 15 Jun 2004 01:33 pm
Tail gate Trim car guy Exterior Accessories Forum 1 23 May 2004 09:05 pm
