PT Cruiser Forum Car Videos
Car Rims
How Many 225/45-17?
Old 09 Sep 2005, 12:51 pm
2step 2step is offline
Default How Many 225/45-17?
Who's mounted 225/45-17's on the stock 17 x 6" rims? I've read reports of some who have gone that wide and also read other reports of installers who declined to mount tires that wide on stock rims.
I know it's pushing it to go that wide on stock rims but if you did it, how did it work out? I have a set and am doing my due diligence, first.[:I]
Old 09 Sep 2005, 01:33 pm
Gary04GT Gary04GT is offline
After much research I decided against the 225/45/17 for my GT stock 17 x 6 rims. Instead, I went with 215/50R-17 tires and found these work quite well--nice profile, better tracking (especially when cornering), and a significantly wider "foot-print" than the stock Goodyears:
http://www.ptcruiserlinks.com/forum/...Terms=GT,tires
No regrets whatsoever. Just my two cents. [8]
Old 09 Sep 2005, 03:20 pm
SteelBlueGT SteelBlueGT is offline
I chose the same size as Gary for my Yokos and I am very happy with the look and fitment and handling upgrade over stock tires and size!! I say if you want bigger tires go with after market wheels and you can go as wide and low aspect ratio as your heart desires.
Old 09 Sep 2005, 11:06 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
i am running 225/45/17 on the stock rims and have had no problems and they grip way better than any other tire combinations i have tried. [8)] Will post pics for you to see later though.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 10 Sep 2005, 01:08 pm
hifiman hifiman is offline
I just went with 215/45/17 Kuhmo's and like them much better over stock. The extra width is barely noticeable.
Old 10 Sep 2005, 01:28 pm
Cal Cruzer Cal Cruzer is offline
215/50/17. A slight increase in diameter and circumfrence but my PT was lowered a little too much in front anyhow and the extra 1/4 inch in diameter gives a little more clearance. I know it doesn't sound like much but it helps. Also fills up the wheel well nicely.
Old 10 Sep 2005, 01:29 pm
aldine aldine is offline
I bought the Avon Tech m500 225/45-17 from the tire rack and brought them to my local Tires Plus to have them mounted on the stock rims. Tires Plus said the side walls were to stiff and they could not mount them so I bought some eight inch wide Borbet rims. I am very happy with the combination, althought I have more than $1000 invested.
Old 09 Oct 2005, 01:11 pm
blueberrygt blueberrygt is offline
I also chose to run 225/45/17 Michelin Pilot Sport PS2's. I had these on my Crossfire as well, and are by far the best tire I've had.
<font color=\"navy\"> <b>
2004 Dream Cruiser</b>
Best ET : 14.1 @ 98 MPH [Automatic]
Mopar Stage 1, Mopar 2.5\" Exhaust, Mopar BOV, Mopar/KW Variant 3 Coilovers, Eibach Sway Bars, 225/45/17 Goodyear GSD3 Tires, MPSC Rotors, Hawk HPS Pads, PTeazer Rollpan, \'06 Taillights, Mopar Navigation and Subwoofer</font id=\"navy\">
<font color=\"red\"> <b>2005 Crossfire SRT-6 </b>
Best ET : 13.4 @ 108 MPH
</font id=\"red\">
Old 10 Oct 2005, 03:25 pm
Also the width of the rim has been debated many times. Concensus seems to be that they width was not 6 inched until the 05's came out with the new wheel. till then it was a 5 inch width.
Old 11 Oct 2005, 02:05 pm
I did a physical measurement when I assisted my installer when my new tires were mounted. The stock OEM 17" GT wheels measure 6 1/4" plus wide inside the flanges. The same wheel is used on '03, '04 and '05. I don't know about the '05 convertible "star" or the new '06.
vB code is On
Harder bumps after changing from 205/50 to 225/45? Jeff V Wheels, Tires, Suspension 8 15 Apr 2005 10:53 am
  Power Rangers | Credit Cards | File Hosting | Destin, Florida | Apply for a credit card
