quote:Originally posted by Tom and Marj Green
Coil over kit goes on next week, lowering the front 2-1/2" and the rear 1-1/2". What are your recommendations for alignment settings on the camber, caster, and toe in. We're more interested in good handling rather than tire wear. Car is a 2006 GT Turbo.
Front toe is the only factory adjustment. You can adjust for front camber using a aftermarket camber kit(smaller dia bolt or eccentric shaped bolt) or you can carefully slot the upper bolt hole in the strut housing to allow for negative front camber. The rear can only be adjusted with shims inserted between the axle mounting and the wheel bearing assembly. I would set front camber a -1.5 deg. and toe at 0. I would set rear @ -2.0 deg. and rear toe-in .15 deg. each side (.30 deg. total). If possible I would try to limit the amount of rake in the vehicle. This car is pretty heavy in the front and a 1" difference in drop front to rear sounds like a lot of rake, even with little rake the vehicle design makes it appear lower in the front than the rear. If you want better handling you should add front and rear sway bars!!! and a LSD, Limited slip diff.
[8)]
