PT Cruiser Forum Car Videos
Car Rims
WHEEL SIZE / 17x8 ?
Old 04 Dec 2005, 08:53 pm
kromans kromans is offline
Default WHEEL SIZE / 17x8 ?
Thinking of a Motegi track lite w/ 35mm offset. Does anyone run 17x8's? Do they fit, especially on the front? Looking at 225x17x45 tires - F1's. Lowered w/ Eibach's.
03 PTGT S1+
Old 05 Dec 2005, 12:01 am
Richard in Idaho Richard in Idaho is online now
I had that question also. I was thinking of 235x17x45 though. I'm I wrong in think that puting a shorter tire on the car woould reduce MPG.
Richard
Old 09 Dec 2005, 12:21 am
Topless in Cali Topless in Cali is offline
The 17X8-35 will work perfect on the GT. The stock rims are a 17X6-35 and on the GT vert, 17X7-35. But since you are going 8" wide, go for the 235/45/17. They will fill the whole wheel well as good as you can without using wheel spacers. I run 225/45/17 on my GT vert' which is as big as I can really go on my 7" wide wheels.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 09 Dec 2005, 02:51 pm
2step 2step is offline
Tire Size Comparison.....Stock vs. Plus Size
Specification/ Sidewall/ Radius/ Diameter/ Circumference/ Revs/Mile
205/50-17...... 4.0in..... 12.5in..... 25.1in...... 78.8in............ 804
235/45-17...... 4.2in..... 12.7in..... 25.3in...... 79.6in............ 796
Actually for all intents and purposes (MPG), the tire sizes are the same.
Old 23 Jan 2006, 12:25 am
PTGT Redman PTGT Redman is offline
FYI, I had a set of Mille Miglia Evo5 on my 01. When I got my 03 GT they wouldnt clear the calipers on the front. The Mille's were 35mm offset, but the 5mm wider front calipers screwed that up. Depending on the thickness of the spoke it may not clear even with the right offset. The stockers barely clear the caliper edge.
Homepage:
Old 03 Mar 2006, 08:59 am
GR8FLPT GR8FLPT is offline
Actually the stock Goodyears RSA's are slightly oversized. Closer to a 215x50x17. dia.
I ended up w/ a set of Bridgestone Potenza G009's in 215x50x17. Car rides great & looks really good. I'll post pics when I get the car cleaned up... we still have winter up here...
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
Old 04 Mar 2006, 03:25 pm
Tom and Marj Green Tom and Marj Green is offline
I just mounted 235/40/17 Kuhmo SPT tires on my Motegi DPK wheels (35mm off set). they fit fine, hit nothing. and the tires are SENSATIONAL - great handling and braking! tom
Old 05 Mar 2006, 05:28 am
SteelBlueGT SteelBlueGT is offline
I have 215/50/17 Yoko all seasons directional tires on stock GT wheels and I love them. Great handling over stock badyears as well as better ride comfort, increased grip in wet and dry, and they are quieter too! I think the slighty bigger tire looks better too!
vB code is On
Tire size on turbo wheel. tomcruz Turbo Wheels/Suspension/Handling 9 11 Jul 2008 03:20 pm
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
GT Wheel Size & Offset jramosGT Turbo Wheels/Suspension/Handling 2 16 Apr 2004 11:25 pm
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
MAX wheel size 19PT Tech & Performance Forum 2 26 Oct 2001 09:12 am
  Debt Consolidation | Tenant Loans | Post Office Credit Card | Remortgage | Comprar piso en Denia
