Rotors
Old 01 Mar 2006, 02:39 pm
Default Rotors
At 36+K I find front rotors are in need of replacement. Has anyone used Frozen Rotors by Diversified Cryogenics?
Old 02 Mar 2006, 10:13 am
Haven't heard of anyone that has..[:I]
Are they the ones Tire Rack advertises?
I went with the best grade NAPA had on my '02 and was very pleased.
Old 04 Apr 2006, 10:33 pm
Send a message via AIM to 03baggedturbo
I sell cross drilled and slotted rotors for the GT and non-turbo PT's
They are made of a denser material then the stock rotors so they will not fade like the stock rotors.. I drill the cross drills.. then come back with a slightly larger big and dimple the hole.. the do the slotts.. then I come back and de-burr the edges of the cuts.. I then zinc coat them so they are rust resistant.. I have had them on PT's for over a year now and I see them at shows still look brand new..
With the new rotors you will get better stopping.. and cooler rotors.. They also look realy nice..
Email me for more information @
Prototypepower@aol.com
Thanks.. Adam
WWW.PROTOTYPEPOWER.COM
Old 04 Apr 2006, 10:54 pm
hey adam, you've got mail !!
Old 05 Apr 2006, 01:30 am
I've got a pair of the slotted/drilled rotors from PrototypePower and love them. They're coupled with Hawk HP pads and the stopping power is terrific. No light surface rust after washing the car either....sweet!!
Adam is a straight up dude too, you'll be very happy dealing with him.
Old 09 Apr 2006, 12:45 pm
how is the brake dust problem ?? or is there no brake dust ??
Old 11 Apr 2006, 07:25 pm
Brake dust is a function of the pads, not the rotors. The Hawk pads I'm using are not a full ceramic so there is some dust, but nowhere near as bad as the factory bits. I tend to be rather, um, let's say, fastidious about maintaining my cars so the PT never really gets "dirty". I will say this though - keep your wheels nicely waxed and the brake dust will come right off with soap and water. Provided you wash your car more often then every other month!
Old 12 Apr 2006, 10:04 pm
Here is a very important update about the slotted/drilled rotors from PrototypePower for anyone concerned about performance. Last weekend I took my car to a local road course track day event where I got to hammer it around an honest to goodness road racing circuit. Never in my life have I worked a set of brakes so darn hard, and since my car is a Turbo Lite I have drum brakes in the rear. With Adam's rotors and the Hawk pads I experienced no fade at all during any of my 30 minute sessions. The car stopped straight and true, and very quickly too! Not a lick of problems and I guarantee you will never use them as hard on the street as I did on the track.
Old 19 Apr 2006, 09:16 pm
tell us more on the track sessions, please.
are you on the "other" site? if so, then I already know, but someone here may want to know.
What else besides the brakes/rotors would you say are required to change? Tires of course.
Suspension?
Engine?
GT
Old 26 Apr 2006, 12:39 am
My car has been lowered 1.5" front and 2" rear with Goldline springs, which are fairly stiff, and damped with Tokico blues. I have a Progress rear anti-sway bar installed but left the stock front unit in place. I'm also running lightweight wheels (about 14lbs each in 17x7 size) and BFGoodrich KDW2 tires in 225/45R17. These are surprisingly sticky and grip really well.
The engine is a Stage 1 equipped Turbo Lite with a VAK system hooked to the factory airbox loaded with a K&N filter. I've also installed the new plastic intake, Magnecor ignition wires and Denso Iridium spark plugs. I've done a cutout of not only the weatherstripping at the cowl, but the metal lip it attaches to as well. The opening is fitted with a mesh screen to seal the engine bay from larger debris (leaves, etc) while letting in plenty of cooling air via cowl induction while in motion, while also letting hot air escape when stationary. Have you ever run your car fairly hard and then tried to touch that aluminum intake with your bare hand? Hurts, doesn't it? I can make a pass at the drag strip or lap a road course for 30 minutes, pop the hood, and hold my hand on the intake for as long as I care to and it won't burn the flesh off my palms. If that isn't proof the setup works, I don't know what is.
NEW ROTORS & CERAMIC PADS littleblueGT Turbo Wheels/Suspension/Handling 22 06 Mar 2007 10:20 pm
Disc Brake Pads and Rotors . Rich Slider Tech & Performance Forum 18 13 Jan 2006 04:27 pm
Warped rotors mgrantom Wheels, Tires, Suspension 4 05 Aug 2004 08:15 am
Please help with rusty new rotors :( gold member The Detail Shop 4 23 Feb 2004 06:50 pm
Factory brake rotors cracking already (under 30k) braindead0 Tech & Performance Forum 6 30 Sep 2003 04:38 pm
