Steering Feel
Old 01 Mar 2006, 06:03 pm
Default Steering Feel
have a04 pt turbo touring ed. Had to have the two front axles replaced because of cv joint problems. I have 34,000 on it. I have noticed that since I got the car back the steering feels lighter...not sloppy or loose just less effort in the wheel. Had the alignement checked and it did need a milor adjust to the front toe...other readings were fine. the dealer says that it might be lighter because of the new axles vs the old with outer cv problems. My question is that anybody out there with a stock pt...no mods to the susp. is you steering firm when you turn it or light. I know that this is a relative type question...but what the heck. It steers fine and acurate it just has a lighter feel or resistance vs prior to the work done....any thoughts...
Old 01 Mar 2006, 06:48 pm
If anyone added a few pounds to the tire pressure, that would lighten up the steering as you have less tire on the road. Check your pressure.
Old 01 Mar 2006, 07:26 pm
35 all the way around...the way I always have them...
Old 05 Mar 2006, 05:23 am
Go to 38 psi and it will feel even better (lighter)
Anyone that has steering problems... Please post nbr10 General Turbo Discussions 38 02 Feb 2009 10:24 am
Want to replace steering wheel-need mechanic advic 500lbgorilla General PT Cruiser Discussions 2 15 Jan 2007 08:24 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
New Steering Wheel at Jegs nhrapt Interior Accessories Forum 2 24 Feb 2004 01:03 am
Click in steering column tcruiser General PT Cruiser Discussions 3 11 Nov 2002 12:25 am
