sway bars ... yet again
Old 19 May 2003, 09:45 pm
Default sway bars ... yet again
As I am new to the forum here, please bear with me. A couple of quick questions regarding sway bars: The Turbo's only have one, the front, so what parts are needed to attach the sway to the rear? In addition, what's the size of the front sway bar included? Are 25MM (front) and 22MM (rear) considered "beefier" sways? Finally, what would ppl suggest to be a good set of aftermarket sways? Progressive? Eibach?
Old 19 May 2003, 10:19 pm
skylight's Avatar
Administrator
Welcome. [|)] i don't know about the thicknesses or aftermarkets, but here's the stock part numbers I got from a dealership..
Old 20 May 2003, 12:40 pm
Buy the parts and put the bar on yourself (it is pretty simple and easy to access)......this is the best favor that you can do for your handling and safety under loaded conditions.
The rear "twist axle that is supposed to give - adequate - sway control only works when there is no load in the back. Load up the back end with weight and the rear gets squirley!
Old 20 May 2003, 10:09 pm
oh, i don't no about the squirely(sp) part. I just had 15 bags of mulch in mine the other day and it rode ok. no sag. sat just about level. thought fer sure it would bottom out. the front bottoms out with no load. But i didn't have to go through no twisties either. Took the off ramp at the normal speed. I was suprised.[8]
Old 22 May 2003, 06:31 pm
I drive between Las Vegas and LA frequently, believe me, I have tested the difference in loaded and unloaded on twisties and in the wind(90mph gusts). There is a HUGE difference in a loaded PT!
Old 24 May 2003, 10:42 pm
Thanks for the info on the DC rear sway - before I go in and order it, how much is it going to cost me (I'll do the install) and are there better/cheaper ones available in the aftermarket?
Thanks,
tezz[8)]
Old 27 May 2003, 05:57 pm
Okay - I bought the parts from the dealer today - friggin' $220 for the parts alone! (Glendale, CA) The yahoos in the service bay didn't even know the new cars didn't come with them! They sent out a tech to look at the belly of the new cars to see how long/how hard it would be to install one (and to make sure I wasn't talking out of my butt, I'm sure). He 'guesstimated' an hour to an hour and a half to install it. After paying this much for the parts, I'll do the job myself. [xx(]
Is there anything in particular I need to know for installation - other than to have the weight back on the wheels before I tighten'er up?
thanks, tezz
tezz
Black 03 PT/GT - Autostick,Stage 1, Mopar BOV, DC rear sway, K&N filter/white baffle out, Magnaflow cat back, Eibach springs, billet strut bar, AMX CAI,3bagged UCP, Euro tail lenses, Revell shifter, misc. do-dads
Old 27 May 2003, 06:10 pm
skylight's Avatar
Administrator
The rear sway package is $166 + shipping, online at Wyckoff..
--> http://store.yahoo.com/wyckoff-chrys...tcroemres.html
Old 27 May 2003, 11:03 pm
DoH!......I wonder if they will jam me with a restocking fee.....thanks
tezz
Old 29 May 2003, 07:12 pm
Install should be a piece of cake, I had to remove my sway bar to install the eibachs.
SUGGESTION: Install the bar on the axle first, then install the frame end rubber mounts on the car. Then swing the bar up and bolt it on. The extra little intermediary arm on each side really makes this easier.
sway bars revisited... comPuTer General PT Cruiser Discussions 2 02 May 2006 04:15 pm
Sway bars quicksilverdon General PT Cruiser Discussions 11 12 Feb 2005 12:15 am
Mopar Sway Bars bigtommy83 Turbo Wheels/Suspension/Handling 6 15 Dec 2004 10:47 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
