PT Cruiser Forum Car Videos
Custom Wheels
I know this might have been beaten to death....
Old 21 Aug 2006, 11:31 pm
Gut Check Gut Check is offline
Default I know this might have been beaten to death....
The one thing that has always grated on me with the PT, especially the 04 GT that I have, is the "butt-in-the-air", DC-seems-to-put-on-every-car rear end (along with the oil tanker turning radius, and unforgivable gas mileage).
I put new tires on the car, and had to go slightly larger because nothing in 205/50-17 really looked satisfying (I really don't want to get crunched and vibrated all the time with "sports" tires). So I have the new Goodyear ResponsEdge 215/50-17 mounted. I do not know when I have loved a tire more. Handling is equal to the RSA's and the reduction in ride harshness and especially road noise is remarkable.
The car did get pushed slightly higher because of the slight increase in tire size, but not uniformly. I know I risk getting branded a rookie, but the front end did NOT go up at all, and the rear went up almost 3/4" (I know, I know, but I measured, from the ground to the top of TDC on the wheel well). So now the unsightly DC rake is even more pronounced.
Here's the question: Can I safely, and without ruining any of the driving characteristics, lower ONLY the rear end? The front already scrapes too much, and it actually looks good with the new beefier rubber. I just want to squat that butt down. I'm thinking that with the butt lower, the center of gravity might improve the steering and response. True?
Thanks so much for any insight.
Old 22 Aug 2006, 12:25 am
SR-PT4 SR-PT4 is offline
First off, yes, it is safe to put a pair of lowering springs on the back only. This will help to "level" the car, but keep in mind that almost all lowering springs on the market are of a higher spring rate than stock, meaning the stock shocks will not be up to the task of controlling them and you really should upgrade rear shocks at the same time. The good news is you do not need a spring compressor to change all these parts on the rear, so anyone with a couple of wrenches can do it. Tricky part is finding JUST the rear springs!!
What I'm really struggling to understand here is how you could replace one set of tires, all four of which were the same size, with another set of tires all of matching size (though different from the originals) and only impact the ride height on the rear. That's sort of like saying "my car was sitting on 2" blocks at all four corners and I changed them all to 4" blocks. now the car sits 2" higher in the back but no different up front" Just doesn't make sense.
As for the improvements you've seen with these new tires (ride harshness, road noise, etc) all I can say is - handling comparable to the RSA's ain't sayin' much!!! Those tires are terrible!!!
Old 22 Aug 2006, 03:17 am
Mean Green Mean Green is online now
With a bigger tire I wonder how much your speedometer is off? If I remember correctly from our '01 PT you are actually going faster than your speedometer says.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 22 Aug 2006, 09:56 am
sca037 sca037 is offline
I have lowered just the rear on our '03GT using the Eibach pro kit, and it's great. I bought the complete spring set, but after mounting the rears have decided to leave it this way. The Eibachs aren't much greater in rate than the stock GT springs, so they work just fine with the stock shocks.
I don't know why the rear is now higher in the air relative to the front after the tire change. Have you removed the rear seats or something? [:I]
Brian
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
Old 28 Aug 2006, 04:56 pm
SteelBlueGT SteelBlueGT is offline
My experience is to put on a qualaity shock with any type of lowering spring. As the shocks wear they will loose whatever control they may have when new. I just loved my Tokicos cause the have a nice smooth ride and far better control especially on rebound. I think my 03 had a better ride overall than my 06 GT does. [8)]
Old 29 Aug 2006, 10:32 am
I lowered the rear only on both my '02 and '05 PTs, and never regretted it.
My '02 springs I bought off a forum memebr who wanted MORE rake, on the '05 I bought a set & just put on the rear - they're cheap enough.
I, too don't like the "butt in the air", also: the front already scrapes sometimes at stock height; the wheel gap is larger in the rear; the rears are far easier to do - no spring compressor, alignment, etc.
If you only drop 2" or less, the stock shocks are fine. I went 87,000 miles on my '02 with the stock shocks, and ride was fine - I dropped 1.5".
Old 30 Aug 2006, 10:42 am
And two inches is a pretty good drop too! On my unmodded 06GT I think the shocks are weak on rebound as I can hear, but not feel, big bumps in the rear of my car.
Old 01 Sep 2006, 01:44 pm
2step 2step is offline
First just a note on how to properly measure a before and after stance. Measure from the lower center of the rim, not the ground, to the center of the wheelwell when switching springs. It's OK to measure wheelwell to ground when just changing tires, though.
Yes, many have changed only the rear springs to level the look. Most (all?) have reported an improvement in ride, too.
vB code is On
Nickle and dime me to death :-( scrisp2 General PT Cruiser Discussions 7 24 Aug 2006 04:10 pm
Death of the snowman! deederz Non-PT Discussions 1 12 Dec 2005 07:05 pm
Death to Idiot Pickup Drivers RetroPT General PT Cruiser Discussions 9 23 Jun 2004 12:12 pm
Do lights/lighter drain battery to death? zzzhuh General PT Cruiser Discussions 11 04 Mar 2004 08:11 am
Those stupid "death" stickers... beebs General PT Cruiser Discussions 13 12 Jun 2003 11:03 am
  Remortgaging | Adverse Credit Remortgage | Bad Credit Mortgages | Charity Gifts | Literatura fantástica
