PT Cruiser Forum Car Videos
Car Rims
problems with lower control arm bushings
  #21 (permalink)
Old 30 Nov 2006, 07:56 am
strangelove strangelove is offline
I'll second that, love my PT, but hate US auto makers business philosophy. I've gone so far as to be looking at cars made in Brazil as being my next car purchase. But to put things into perspective, I'm going on five years with my PT and no major problems, so for me I'm a happy camper.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
  #22 (permalink)
Old 30 Nov 2006, 02:31 pm
fritz_t_coyote fritz_t_coyote is offline
It's NOT country of manufacture, US-built Hondas and Toyotas are just a reliable as their Japanese cousins.
It is 'mindset of management'.
www.visualizecommonsense.com
  #23 (permalink)
Old 30 Nov 2006, 04:13 pm
rszappa1 rszappa1 is offline
and the quality of parts used....
  #24 (permalink)
Old 30 Nov 2006, 06:11 pm
Right I like US cars, I just don't like US car manufacturers business philosophy of building cars cheap fast and overpriced and on the verge of being outdated technology wise. Reason why Honda and Toyota's cars are so much better is that they have the right business philosophy of building the best most reliable cars available with stringent emission and fuel efficiency standards. German cars are known for engineering to make the cars faster and handle better. US cars are known for... made for the masses. Kind of like when you think of China cars or even India cars, which are made for the Mass of Masses and are built even cheaper then US cars. Now what do you think of when you hear about Brazilian cars? To me I think fuel efficient, well engineered, and cheap to boot, because what gets imported to the US is the best that Brazil produces.
  #25 (permalink)
Old 06 Mar 2007, 10:35 pm
gillclay gillclay is offline
quote:Originally posted by ValAir
Has anyone out there had problems with their lower control arm bushings ripping? I had to have mine replaced 3 times in the past 2.5 years. finally the dealership replaced the lower control arms completely. Luckily I bought an extended warranty.
Val
I own two 02 neons.One has had both replaced once with 20,000 miles and the other with 110,000 has had them both changed 4 times. I did the job each time.I just got done tonight putting Energy suspension urethane bushings in.Chrysler wont admit a problem.I was on the phone with them in Detroit. I found 9 neons in the lot at work with bad ones. They did not know this or even care."they just drive them". The suspension is the same in the pt's. Im betting the urethanes will work. It took two afternoons to do this.
Homer
  #26 (permalink)
Old 11 Mar 2007, 09:48 am
ddakin ddakin is offline
Send a message via MSN to ddakin
Could you PLEASE, PLEASE take a few minutes to explain how you replaced the control arm bushings?
I'm new to the forums here as I just bought my 2003 PT GT and, like most people on here, my bushings are bad too. I'm buying the Energy Suspension ones, but I'm getting installation prices ranging from $200 to $400. I'm mechanically inclined so I know I can probably do this, but I'm told I need to press fit the bushings, which means I may not be able to???
Help!
Cheers,
Dan
(Niagara Falls Canada)
Val
2003 PT Cruiser GT
  #27 (permalink)
Old 11 Mar 2007, 11:17 pm
Sturdevant Sturdevant is offline
www.steve.sturdevant.com/LCA.pdf
A machine shop can press the old out and the new in.
  #28 (permalink)
Old 14 Mar 2007, 01:02 am
ValAir ValAir is offline
Everything has been fine so far with the dealer replacing both lower control arms.........they must have upgraded the bushings or something. This problem is one of the reasons I bought an extended warranty for the car!
The bushings seems to be fine so far........but there is some slight tearing starting.
\'03 GT Black, 5 speed, Chrysler/Borla dual exhaust, Chysler performance air filter, Stage 1 kit, Plastic Intake, Chrysler B.O.V.,
Magnecore wires.
  #29 (permalink)
Old 14 Mar 2007, 11:33 pm
Glad to hear that you got it fixed. Sad to hear that you are seeing it tear already. For what it's worth, I ran with those rubber bushings torn for quite a while before replacing them. You might feel some looseness in the steering. You might hear some creaking when you go over speed bumps, but that's about it. The way the bushing works now is just to keep metal from rubbing on metal, so if there is still a bushing there, torn or not it's doing it's job.
  #30 (permalink)
Old 15 Mar 2007, 07:55 pm
strange,
I deal with the rips up until is bugs the hell out of me hearing all of the racket when i hit a bump. Then I have them replaced, it's covered under my extended warranty and it helps to know the guys at the Chrysler dealership.
Magnecore wires.
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Control Arm Bushings jaspersnowstorm Turbo Wheels/Suspension/Handling 3 21 Aug 2005 09:52 am
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
  Loans | Loans | Loans | Car Insurance | Loans
