PT Cruiser Forum Car Videos
Custom Wheels
problems with lower control arm bushings
Old 19 Sep 2006, 08:45 pm
ValAir ValAir is offline
Default problems with lower control arm bushings
Has anyone out there had problems with their lower control arm bushings ripping? I had to have mine replaced 3 times in the past 2.5 years. finally the dealership replaced the lower control arms completely. Luckily I bought an extended warranty.
Val
Old 19 Sep 2006, 09:58 pm
bobs turbo pt bobs turbo pt is offline
i had same problem but they changed everything first time back at dealership
Old 20 Sep 2006, 08:58 am
sca037 sca037 is offline
When my lower control arm bushings start to deteriorate, I will get a full urethane bushing kit and redo the entire front end with those.
Problem solved [?]
Brian
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
Old 20 Sep 2006, 11:53 pm
Brian, where do you pick these kits up at?
\'03 GT Black, 5 speed, Chrysler/Borla dual exhaust, Chysler performance air filter, Stage 1 kit, Plastic Intake, Chrysler B.O.V.,
Magnecore wires.
Old 21 Sep 2006, 02:27 pm
Val, the kit I am going to use is made by Energy Suspension.
You can find the part number(s) on their website here:
http://www.energysuspension.com/pages/cry3.html
Then order it from the retailer of your choice [8D]
Cheers,
Brian
Old 23 Sep 2006, 01:01 am
EJIII EJIII is offline
My dealer just replaced both of my PT's lower control arms last week, under warranty, at 38K miles. My only symptom was an intermittant clunk over potholes in the dirt road that we live on. I'd been after them about it since last winter and I guess the lube guy found the problem while changing the oil last month. When I picked up the car they told me what they found and that the parts were already on order. That's why I drive past the Chrysler dealer in our town to get to the Dodge Boys.
Almost to 40K now and O.E. tires and brakes are still good! I cheated on the tires last winter with a set of snows, but the brakes were still over 50% when the old tires went back on last spring. I still love this car!
\'07 Cognac Town and Country Touring - no turbo
Old 16 Nov 2006, 08:49 am
strangelove strangelove is offline
I'd replace them with something better than just urethane bushings, the control arm bushing is a weak point in the PT suspension and everyone seems to have problems with there bushings tearing. If I were you I'd get these from rag-tek
http://www.rage-tek.com/product.php?...1&cat=0&page=1
I have had similar type made from Psi-Fi that have been going strong for over 50,000 miles. Smoothes things out during heavy acceleration, and better handling. The only thing I've found is that you need to be careful when pulling up on to a curb, since they get kind of creaky, but that's the tradeoff, need for caution for better performance.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 17 Nov 2006, 08:15 pm
Nudle Nudle is offline
[^]Took my 03gt to the dealer for a oil change.70000Kms, They told me that the lower control arm bushing needed to be replaced.They replaced the complete lower control arms under warranty.I had to pay for a wheel alinment.
nudle
Old 18 Nov 2006, 03:23 am
ote69 ote69 is offline
when is dc going to admit to a faulty and potentially dagerous product and recall them? This same defect is happening in the neons and mini vans.
Old 18 Nov 2006, 07:39 am
I don't know if it is particularly dangerouse, since all it is, is a bushing, the bolt is really whats holding the control arm in place. When it's worn steering gets kind of squirly during heavy acceleration and rough roads. Most cars get squirly after a few years anyways, as long as the bolts hold then DC would have no reason to claim it as a defect, they would see it as normal wear and tear. Now if DC new about the problem and didn't phase out the part then they would be liable if someone were to get hurt, and I would think it would be in there best interest to at least do a re-design of the part for future models.
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Control Arm Bushings jaspersnowstorm Turbo Wheels/Suspension/Handling 3 21 Aug 2005 09:52 am
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
  Advertising | AboutAmericaNow | Loans | Internet Advertising | iPhone Reviews
