PT Cruiser Forum Car Videos
Car Rims
rear Sway Bar 2006 GT
Old 29 Sep 2006, 05:14 am
SteelBlueGT SteelBlueGT is offline
Default rear Sway Bar 2006 GT
Does anyone know if the all new for 06 GT's still have all the mounting holes for the way bar and will my 03 install kit work on an 06??
Old 29 Sep 2006, 09:00 am
Grab a sheet of cardbord, put it on the ground, lay down & look - then you'll know.
What I can tell you is that sometime in '05 they stopped putting in the captive nuts in the recess, and the Mopar mounting kit I got was short those 2 nuts - got them at home Depot - I took a bolt with me - I'll save you a lot of time - they are METRIC.
I also came up with a trick - stuff a piece of paper towel in the recess to hold the nut up to the hole so you can start the bolt. Then, take a BFS (Big, F...ing Screwdriver) and wedge it agaist a flat on the nut while you tighten the bolt - you can't get a wrench in there. AND those bolts have to be TIGHT.
Old 29 Sep 2006, 04:02 pm
I will look again but I casually looked when I bought the car and I could not find the mounting holes. But if I remember they were kinda out of the way and I only found them on my 03 when I had the bar and linkage kit in hand and they guided me to the mounting locations.
Old 10 Oct 2006, 04:18 pm
Tom and Marj Green Tom and Marj Green is offline
Just had Eibach rear sway bar and Chyrsler sway bar mounting kit installed on my 2006 GT. no problem; very simple bolt on. Turbo Tommy
Old 27 Nov 2006, 03:43 pm
Thank You I have ordered my H&R adjustable bar and Eibach intall kit!
Old 28 Nov 2006, 10:05 am
Hope you have better luck than most with the Eibach mounting kit - many have had problems - the Mopar mounting kit is actually better!
Old 06 Jan 2007, 04:56 pm
It may be better but I have got a lot of extra parts now from Eibach and they did make good on my last ones that were defective from my 2003. Seems that the parts that went bad were supose to be solid but the outside vendor made them hallow and mine rusted / corroded out and broke. New ones are solid. Now I just need to figure out how to get rid of the squeek in my 06 install bushings!!
Old 08 Jan 2007, 12:39 pm
hharper1321's Avatar
hharper1321 hharper1321 is offline
Good tips, but for a bit more info, they didn't include any captive nuts on my 04, either...
2004 PTGT - Stage 1 and a bunch of bolt-ons, even more bolt-ons waiting in the garage!
How come "The People" in the First Amendment means The People; "the People" in the Fourth Amendment means The People; but "the People" in the Second Amendment (ratified in 1791) means the National Guard (created by an Act of Congress in 1903)?
vB code is On
Rear sway bar kit turbomangt Turbo Wheels/Suspension/Handling 10 05 Jul 2005 12:40 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
  Free Ringtones | Charity | Compare Credit Cards | Remortgages | 0 Credit Cards
