| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
What brand were they...and does the box say made in China?
do your rotors have a min thickness stamped into the rotor hat. A manufacturer name, part number and lot number? Where were they made? What is there composition? Are they alloyed grey iron, or some Chinese pig iron? Are they dynamically balanced? Again, you get what you pay for......
Cant agree with you more....[?]
They had the dimensions and part number stamped on the outside diameter and I'm not going to take the tire off to look for more. They were made by Prostop which was the same manufacturer of the ceramic brake pads (with wear indicators). I like them,so I will buy the rear rotors as well. This posting was only meant to inform other PT owners that other options are available,especially if they don't have a lot of money to spend.If I post something it's only to inform others of alternatives, and I never expected a pat on the back. If you don't like what I have posted, I really don't care.
Is this the type of brake rotor you got?
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold. Mods On The Way: AGP Wastegate Actuator |
Pep Boys have a set of these for sale $37.99 a set
That is the type I asked for, but they didn't have it for the GT Turbo, only the standard undrilled was available. I stopped there on the way home from work as I heard "metal to metal" in stop and go driving, so I had to get the parts quick! I replaced the brake pads and rotors the next morning and found that the OEM rear pads didn't have wear indicators.
Yep OEM pads, suck. Reason why the rear pads don't have wear indicators is that the rear pads rarely wear all the way down, it's the fronts that go first. The manufacturer of the OEM part probably wanted to cut back on costs so told their engineers to scale down parts as much as possible.
I am not real happy with the ceramic pads. They are very low dusting,they are quiet, they don't fade as the oems, but they do seem to require more pedal pressure to stop. I may go back to the semi metalics.
| Front ceramic front brake pads | coopj40 | General Turbo Discussions | 1 | 17 Mar 2007 06:42 pm |
| Disc Brake Pads and Rotors . | Rich Slider | Tech & Performance Forum | 18 | 13 Jan 2006 04:27 pm |
| Morse ceramic pads? | Hill Cruiser | General PT Cruiser Discussions | 7 | 15 Aug 2005 04:44 pm |
| Akebono Ceramic Pads for 03 GT | mangusta1969 | Turbo Wheels/Suspension/Handling | 11 | 03 Oct 2004 06:04 pm |
| Akebono Ceramic Pads | Stephen R. | Wheels, Tires, Suspension | 9 | 23 Mar 2004 11:54 pm |
