PT Cruiser Forum Car Videos
Car Rims
Alignment Kits?
Old 12 Aug 2007, 05:15 pm
biggus127 biggus127 is offline
Default Alignment Kits?
I've ordered some lowering springs from Tire Rack and they suggest a "alignment kit". It looks like some odd looking bolts and washers for the front end, my question is are they really necessary, or is it just some way to get another $30 out of me? Thanks D.
Old 12 Aug 2007, 07:05 pm
CREWZIN CREWZIN is offline
Default Re: Alignment Kits?
It's necessary if your front end needs to be aligned. Yea, that's all it is ....2 bolts that go on to the bottom of the strut. It replaces the bottom bolt (of two) and it's an odd shaped bolt so when they turn the bolt it changes/adjusts the ??camber - caster?? toe ?? (I forget which) but without the bolts, it can't be adjusted to the right specs.
Why the HECK didn't Chrysler put those stupid bolts in, in the first place, is beyond the normal range of thinking.
And YES, you can find them a little cheaper maybe on eBay (that's where I got mine ($19) but then I paid for shipping so I didn't save anything.
Old 13 Aug 2007, 06:59 am
apexanimal's Avatar
apexanimal apexanimal is offline
Send a message via AIM to apexanimal
changes camber...
how low are your springs going to put you? if it's just 1"-1.5" you'll be alright, but 1.5" and over get some... it'll help b/c you DONT want positive camber.
'03 GT 5spd: Stage 1+
http://www.cardomain.com/ride/2272425
http://www.ptboutique.com
Old 14 Aug 2007, 10:22 pm
I've ordered the springs and the alignment kit, can't wait to get them on and see how much better this will corner, i figured for $25 it couldn't be all bad. Any suggestions about the install, looks like the rears will be a piece of cake and the fronts just take your time and do it right. But is there anything I'm missing?
Old 15 Aug 2007, 02:14 am
Mean Green Mean Green is offline
I've had two PTs lowered with Eibach springs (1.6 front, 2 back) and haven't needed the camber kit. Some do, most don't. Your cornering will improve to a point, but you'll still need better sway bars,Tokico shocks, poly bushings and a front strut bar. If you are made of money then some wider tires would be nice, too, but if you are keeping it on the sane side then just springs will be nice.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 19 Aug 2007, 05:57 pm
Smile Re: Alignment Kits?
Install the springs today, took about 5 hours, and i got a 2 1/4 inch drop in the reat and 1 3/4 drop in the front, really like the way it looks and the ride and cornering is improved, I didn't install the alignment kit, it wasn't very obvious just what it replaces, I'll wait until i get an alignment check and if it needs the kit they can put it on. I did notice as I was brushing the grit off the front brake calipers, stamped into them it says TURBO on them, it's nice to have bigger brakes.
vB code is On
I cant get an alignment with 20's goldline springs ptcruz311 Wheels, Tires, Suspension 6 02 Aug 2006 05:28 pm
Lowering Kit and Alignment CREWZIN Wheels, Tires, Suspension 13 11 Jan 2005 03:38 pm
Mopar Gauages and Stage 1 kits in Canada GLH_TC 16V Vendors & Buyers Forum 1 12 Sep 2003 12:57 pm
stage 1 kits are here tthrift Turbo Performance 16 27 Jun 2003 09:33 pm
Alignment Kits jramosGT Tech & Performance Forum 6 14 Jan 2003 12:47 pm
  Payday Loans | Life Insurance | Babb Fest | Bad Credit Mortgages | Mortgages
