Engine Brace/Strut Tower
Old 06 Sep 2007, 03:19 pm
Default Engine Brace/Strut Tower
I am trying to find an Engine Brace or Strut tower or a 2005 GT Cruiser.
BTG's supplier of the Shock Tower is no longer making them, I contacted Wyckoff but they said that 'PT Cruiser Strut Tower bar' the Turbo version will not fit the GT.
I prefer the look and size of BTG's Shock Tower brace, does anyone have any suggestions?
I do intend to get the anti-sway bars but this will be in addition and something I want to do now.
Thanks for any suggestions!
05turbomtx (late '05 gt - 230HP), S1, bov, Hurst short throw, borla catback, srt boost gauge, srt air/fuel gauge, mopar cold air intake, wildfire strut brace, magnecor 10mm
Old 06 Sep 2007, 04:09 pm
apexanimal's Avatar
Send a message via AIM to apexanimal
Default Re: Engine Brace/Strut Tower
the only one i recommend is the wildfire from race and street... good stuff.
you will have to modify the solenoid bracket but that's fairly easy.
'03 GT 5spd: Stage 1+
http://www.cardomain.com/ride/2272425
http://www.ptboutique.com
Old 06 Sep 2007, 08:31 pm
I checked it out and it looks good! thanks bro!
Old 20 Sep 2007, 10:50 am
Dream4's Avatar
I sold my BTG Aluminum bar in favor of the Wildfire Chrome moly steel bar, a lot stiffer, stronger bar, and has a nice powder coated finish, and does not rub the hood insulation like the BTG did when it flexed on hard turns.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
Old 13 May 2008, 03:01 pm
nevinsrt's Avatar
great site!!! thanks!!!
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
Strut Nut Problem with BTG Tower Brace purplept Turbo Wheels/Suspension/Handling 9 09 Jul 2004 08:06 pm
Strut Tower Bar and/or Anti-Sway Kit zzrogue Wheels, Tires, Suspension 4 04 Jul 2004 07:17 pm
