HAWK Brake Pads
Old 13 May 2008, 04:29 pm
nevinsrt's Avatar
Default HAWK Brake Pads
Ive been looking for some HPS or HP+ front and rear pads for my wifes 05 GT HO we mainly do AutoX so im looking for at least HPS pads for great stopping power
ive looked in other threads and haven't found any info.
would someone point me in the right direction.
are the front pads on the GT HO the same as an SRT
Ive found the rears and there an SRT Match
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 13 May 2008, 04:31 pm
Default Re: HAWK Brake Pads
Not sure about the PT, but I put Hawk Performance pads on my Vette and they work great. No fade, little dust and don't seem to fade.
Old 13 May 2008, 04:36 pm
nevinsrt's Avatar
we had them on her Cavalier when we traded them in. so I need to find a set for the Cruiser so she can continue to play.
Hawk are the best pads ive ever used. nice strong bite.
Nevin.
Old 15 May 2008, 11:29 pm
nevinsrt's Avatar
I found my answer
2003 CHRYSLER PT CRUISER TURBO
2004-2005 CHRYSLER PT CRUISER HO TURBO - GT, SERIES 3
2006-2007 CHRYSLER PT CRUISER HO TURBO - GT
2003-2005 DODGE SRT-4
Front Rotor: 121. 63053
Rear Rotor: 121.63054
Front Hawk : HB377F.760
Rear Hawk : HB176F.614
Nevin.
ceramic vs. semi-metallic brake pads pppt03turbo General Turbo Discussions 10 23 May 2008 09:06 am
Disc Brake Pads and Rotors . Rich Slider Tech & Performance Forum 18 13 Jan 2006 04:27 pm
New Brake Pads Gunner General Turbo Discussions 12 02 Apr 2004 03:26 pm
Aftermarket brake pads MEXICANPT Turbo Wheels/Suspension/Handling 9 19 Dec 2003 06:31 pm
Greenstuff Brake Pads anyone? GTSteve General Turbo Discussions 9 17 Sep 2003 08:05 pm
