Since the SRT-4 and the GT HO have the same rotors, brakes, and calipers then these will work
i have them on the my SRT and they work great for AutoX/RR days these speed bleeders are easy to install and use and only require you for bleeding. The wifes speed bleeders have been order and should be here in a few days. heres the info. The size(s) that you need for your application is as follows: Front....SB1010S Rear.....SB1010 When you order Speed Bleeder consider ordering the "Bleeder / Bag Combo". It will make bleeding your brakes even easier. It consists of a 30 inch length of silicone tubing that is specifically sized to the Speed Bleeders and a bleeder bag that looks like an IV bag that is used in hospitals. Attach one end of the hose to the Speed Bleeder nipple and the other end to the bleeder bag. Open the Speed Bleeder 1/4 turn and proceed to bleed your caliper or wheel cylinder. The fluid will be contained in the bleeder bag and eliminates any unnecessary mess. Speed Bleeder can be ordered at: Speed Bleeder Products, Inc Home
Nevin. 03 SRT-4 — 132k mi ported stocker and lots of other stuff 68 Mustang Coupe — project fail!! PT Less - ex wife took in the divorce 3/2011 05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08 3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Is the 4 Speed A/S realy a six speed? | Ian-PT-GT | General Turbo Discussions | 11 | 16 Apr 2004 10:19 pm |
| Top Speed Limited? | BlueBlurCruiser | General PT Cruiser Discussions | 23 | 22 Mar 2004 06:48 pm |
| Forced Induction w/ Speed Density? | Steve03GT | Turbo Performance | 3 | 18 Jul 2003 06:20 pm |
| Confirmed/ design flaw T-5 speed | turbomangt | Tech & Performance Forum | 6 | 06 Feb 2003 09:32 am |
