Raising Front of Vehicle
Old 03 Jul 2008, 10:58 pm
Default Raising Front of Vehicle
I want to raise the front of my 03 GT ATX about one inch or so. I know I could put wedges in the spring coils, but that will amplify bumps and otherwise cause the ride to suffer. Does anyone know if there are coil springs from other PT or SRT Chrysler vehicles that would raise the ride height? Possibly from a convertible model?
Old 04 Jul 2008, 11:29 am
Dream4's Avatar
Default Re: Raising Front of Vehicle
I have not seen any springs to raise the front of a PT, even the adjustable Mopar Stage 2 coil overs I have will only go from stock height to 40mm lower, not higher than stock, the convertible does weigh about 300 lbs more than the sedan, but I don't think that the 100+ pounds difference in the front springs would make a full inch difference.
The springs on the SRT4s will fit, but they are a lot lighter, so they will not help either.
Why do you want to raise the front, instead of lowering the rear, this is the first time I have ever heard of anyone wanting to raise the front, as it is already very high to start with.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
Old 04 Jul 2008, 11:22 pm
I want to raise the front to keep from scraping more parking lot bumpers and steep driveway entrys. The distance from the garage floor to the lower lip of the front fender is 26.5 inches measured through the wheel axis. I'm going to replace the struts with Tokico Blues so it would be a good time to replace the springs. I know that Chrysler has charts that show spring rate, free length and ride height. Sure would be nice if someone here had that info.
Old 05 Jul 2008, 12:28 am
PTmodrod's Avatar
Well like you said before, you could block them. If you put the blocks at one end or the other of the spring (on top of or underneath), the ride will not suffer because the spring will act the same as they did before.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Old 08 Jul 2008, 07:24 am
If you lower the rear, it does raise the front up a little - My headlights went up a bit when I did rear springs.
Front license plate placement spicy pt Exterior & Interior Styling 50 16 Oct 2008 08:52 pm
2006 Chrylser PT Cruiser Touring (san jose north) $10999 skylight craigslist 0 16 Jul 2007 05:20 pm
Inilex Satellite Tracking System for PT Cruiser Tee It High General PT Cruiser Discussions 4 18 Jan 2005 11:47 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
