I just had the stage 2 suspension coil over etc...done and the stage 1 sway bars...does anyone else have this? Any problems? Very firm ride now and can corner like a viper!
Congrats. Any power mods on the agenda?
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
A couple of questions for you...What is a check valve and where did you get your steel braided flex lines for the front and do they make them for the rear, and if so why haven't you done them as well? Or are they worth doing the rears???
you can use the steel braided brake lines from SRT-4s as well as the f/r brake pads, f/r rotors. when it comes to the back i havent found any steel lines for it yet other wise i'd already done them.
Nevin. 03 SRT-4 132k mi ported stocker and lots of other stuff 68 Mustang Coupe project fail!! PT Less - ex wife took in the divorce 3/2011 05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08 3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge |
Thank you for the info. I will order the check valve/catch can and the steel braided flex lines. What else can I do to this car???
you need to be more specific.
I have the top of the line suspension, PT Teaser front end and lots of custom stuff, BOV, 10mm wires, Stage 1, special pipes, cold air intake etc...Howabout an inner cooler, I will get the brakes done front and rear, what else can you suggest, I do have the MOPAR Borla 3" stainless steel cat back exhaust
Intercooler Question 5th post down. and what else i suggest is what ever direction you want to go. wether you want suspention, power or looks.
Yes, go to ptcrew.com as they have people at all different levels of performance. Right now the only power mod you have is stage 1.
| Are there any step by step instructions for mopar stage 2 wastegate and or dual stage | dmkolb | Turbo Performance | 7 | 04 Aug 2010 03:44 pm |
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| Stage 1 and 2 modules on Ebay | pdbrains | Stage Turbo Kits | 3 | 16 Aug 2007 12:06 pm |
| Is Mopar Stage 1 Suspension for Real? | MichaelDay | Turbo Wheels/Suspension/Handling | 9 | 06 May 2004 04:58 pm |
| Stage 2 info from SRT-4 site | dtbrks | Stage Turbo Kits | 24 | 26 Nov 2003 05:24 pm |
