brake upgrade
  #21 (permalink)
Old 24 Dec 2008, 09:11 am
nevinsrt's Avatar
Default Re: brake upgrade
Originally Posted by lakersfan1 View Post
I don't remember the inquirer saying anything about racing. From a normal-driving standpoint, the Satisfied Ceramic are better than stock. If you're going to be doing laps, Satisfied GranSport are better suited for Street/Track use.
hawk hps are a street/track pad
hawk hp+ are a track pad and were using them on the street and no problems and racing is only 2-3 times a month the rest of the time is spent comuting to and from work. and im shareing my real life experiences with them and in good and hard driving conditions
the Satisfied Ceramics were used the same way and they didnt give me that warm and fuzzy like the Hawks do.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
  #22 (permalink)
Old 24 Dec 2008, 09:26 am
nevinsrt's Avatar
Originally Posted by superpug666 View Post
all i want, is a higher performance brake combo of stock dimension , that wont be too loud, because i can live with a lil bit of swqueak.... But they have to perform without the need of being heated, since theyre used on the streets.....
Hawk HPS pads
Modern Performance Racing Products
$65 for the front and $55 for the rear
and even if you stepped it up and got the HP+
$90 front and $76 rear
Satisfied Performance Brakes
Pro Ceramic $121 front and $64 rear.
OEM pads $50 front and $50 rear
https://www.turboneonstore.com/custo...5&bestseller=Y
Nevin.
  #23 (permalink)
Old 25 Dec 2008, 12:41 pm
superpug666's Avatar
Originally Posted by nevinsrt View Post
Hawk HPS pads
thanks Nevinsrt, the fact that you have track exp, does help a lot, because i can relate to it if i decide to have "fun" on the street and so on. greatly apreciated. from you all!
merry xmas
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
  #24 (permalink)
Old 25 Dec 2008, 02:53 pm
The Satisifed are more like $65 at Kragen, and $75 at TireRack.com ..... but if you can get the Hawks at that price point, it kind of makes it a more attractive option.
  #25 (permalink)
Old 16 Apr 2009, 12:42 pm
thatrotorshop's Avatar
I sell cross drilled and slotted anadized rotors for the pt turbo and non turbo..
$230 for all 4.... then get nice ceramic pads and you will love it...
all of my pictures are too big to upload.. email me and I can send you a lot of pictures...
Thanks.. Adam
ThatRotorShop.com (comming soon)
ThatRotorShop@aol.com
  #26 (permalink)
Old 15 Jun 2009, 11:43 pm
So I'm sticking with hawk hps (no scream and way less dust) but which rotors?
Must be drilled and/or slotted and I'm looking at Brembo, DBA or EBC.
Any recommendations?
2003 Black GT autostick
  #27 (permalink)
Old 16 Jun 2009, 04:30 pm
EBC Ultimax. They're slotted, not drilled. Should be able to get for less than $150 a pair. They have a high temp paint throughout so no rust forms on the non-contact surfaces. They also contain a little copper in the mix to help dissipate heat. Made in England, so no cheap Chinese iron
  #28 (permalink)
Old 16 Jun 2009, 11:08 pm
Thank you, but I looked into them a bit and I need something built for street and track use. Ultimax seems to be for street only. I should have mentioned that...
  #29 (permalink)
Old 17 Jun 2009, 01:41 pm
Does anyone have an opinion re: XtremeStop rotors? I've done some research and it all seems good...
  #30 (permalink)
Old 17 Jun 2009, 07:47 pm
Ultimax are the SAME EXACT blanks as thier low line and high-line rotors with the same build material and quality. All that it lacks from thier high-line is it doesn't have cross-drilling ..... which is a waste of time IMO in all but the most extreme sports applications. And even then, our factory rotors are so small you can't afford to lose surface area for cross-drilling. On top of the problems with cracked rotors from cross-drilling.
Latest Info on Disc Brake Upgrade blue General PT Cruiser Discussions 5 12 May 2005 02:32 am
REAR DRUM BRAKE TO DISC UPGRADE blue General PT Cruiser Discussions 18 04 May 2005 09:51 am
Brake Upgrade Kit jaspersnowstorm General Turbo Discussions 10 16 Feb 2005 06:31 am
brake upgrade sipb Vendors & Buyers Forum 13 22 May 2004 03:24 pm
NEW, "Big Brake" Upgrade! Intorductory Pricing PremierAutomotive Vendors & Buyers Forum 0 23 Aug 2002 03:31 pm
