Calipers are rusted? I'm sure they still work.
You're not going to get much better performance then OEM pads w/o going big, like the 13.5" Stoptechs.
2006 GT Convertible 5-speed Black Eibach springs/ST sway bars 19x8.5 ADR wheels 235/35, 245/35 General UHPs 20% tint/XenonEyes HIDs PTeazer Roll Pan Borla dual 2.5" cat back
Personally, I don't trust rusted calipers. I replace them (easy!) However, that being said, if the rubber seals are not dry, or cracked, or in generally rough condition, you might be able to get away with using them. If any sign of problems, however slight, replace (or rebuild) that sucker. Brakes are your front line of defense - don't cheap out on them.
I drive an hybrid, it burns both gas and rubber!!!!! To hell with all religions! Yes my baby is stock, for now! |
Honestly I think it's silly to consider your crappy winter wheels when determining brakes. Wilwood brakes up front are only $550 for the set with everything you need to go to 12" rotors. All new calipers, pads, and rotors and you're already pushing $300 just to keep the same level of performance. :shrug:
Answer: Hawk HP+ pads there replacement pads.
when looking for them there the same pads as an SRT-4
Nevin. 03 SRT-4 — 132k mi ported stocker and lots of other stuff 68 Mustang Coupe — project fail!! PT Less - ex wife took in the divorce 3/2011 05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08 3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge Last edited by nevinsrt; 09 Dec 2008 at 10:38 am. |
what you can do to protect them is by some caliper paint and paint them, that should keep them from rusting in the future. as for rear brakes do the same HP+ these brakes have a break in process and it involves hard to moderate repeated stops read the directions and follow them, you just cant put them on and use them, even if you went with a lower HPS you still have to break them in. and get new rotors while your at it. if you dont like stopping hard, the sound of brake squeel, and/or brake dust then dont buy them, they are an autocross/track pad. these pads work.
Nevin. 03 SRT-4 — 132k mi ported stocker and lots of other stuff 68 Mustang Coupe — project fail!! PT Less - ex wife took in the divorce 3/2011 05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08 3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge |
| Latest Info on Disc Brake Upgrade | blue | General PT Cruiser Discussions | 5 | 12 May 2005 02:32 am |
| REAR DRUM BRAKE TO DISC UPGRADE | blue | General PT Cruiser Discussions | 18 | 04 May 2005 09:51 am |
| Brake Upgrade Kit | jaspersnowstorm | General Turbo Discussions | 10 | 16 Feb 2005 06:31 am |
| brake upgrade | sipb | Vendors & Buyers Forum | 13 | 22 May 2004 03:24 pm |
| NEW, "Big Brake" Upgrade! Intorductory Pricing | PremierAutomotive | Vendors & Buyers Forum | 0 | 23 Aug 2002 03:31 pm |
