tire size question
Old 10 Dec 2008, 07:22 pm
Default tire size question
I am in need of finally replacing my tires. I want to go with 215/50 on the front and 225/50 on the rear.
Just wanted to make sure noone had an interference problem with the 215 hitting anywhere.
Also, will the 225 stick out past the wheel well?
thanks
Old 10 Dec 2008, 09:17 pm
soonercruiser's Avatar
Cool Re: tire size question
Since you won't be able to do a full tire rotation with this scheme, be sure to not get uni-directional tires. I didn't even know my tire were that way, until they got here. You wouldn't be able to rotate left to right, or vice versa.
Frank, aka SOONERCRUISER,
Old 11 Dec 2008, 10:04 pm
Default Re: tire size question
Also, if you have ABS brakes, different diameter tires can cause the abs system to act weird due to differing rotational speeds of the tires. There won't really be much visible difference in those two sizes of tires. I would stick with the same size all around and be able to rotate the tires.
Old 12 Dec 2008, 01:22 pm
thank you, I did not think of the ABS difficulties
Newbie with Wheel/Tire Size Question digitalpinscruiser Wheels, Tires, Suspension 6 27 Jun 2008 06:04 am
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
