Bad handling, need help.
Old 15 Dec 2008, 11:54 am
Default Bad handling, need help.
I have a 2003 gt with 77,000km's. I just got a set of toyo garit winter tires installed and ever since when I am travelling at a higher speed 90-110kms or 35-55mph the car wanders.
When I accelerate it goes right and when I decelerate it goes left. And when I correct the "wander" the car feels loose and wobbles.
any ideas?
Old 15 Dec 2008, 05:27 pm
nevinsrt's Avatar
Default Re: Bad handling, need help.
any ideas?
maybe you need an alingment.
get that check first.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 17 Dec 2008, 06:50 pm
And check your tire pressure as well...
Old 18 Dec 2008, 11:29 am
crusierdad76's Avatar
this may sound foolish but make sure the wheels are fitting tight the to the hub and the lugs are tight
Old 18 Dec 2008, 07:49 pm
I would suspect that one or more of the new tires has a bad belt somewhere. My pt did a similar behaviour after I hit a pothole. New tire fixed it.
2006 GT Poor Handling jayguliano Turbo Wheels/Suspension/Handling 18 04 Feb 2007 03:21 am
I thought my Pt Cruiser was a good handling car... Konkeler General PT Cruiser Discussions 18 09 Nov 2004 11:11 pm
Cargo Handling Question NewBluCruzr Turbo Wheels/Suspension/Handling 3 30 Jun 2004 02:12 am
What's the best mod to improve handling ? Wingdale Dave Turbo Wheels/Suspension/Handling 15 03 Jun 2004 11:03 pm
New Eibach Springs ! Great Handling FRM3 Stage Turbo Kits 13 18 Oct 2003 09:50 pm
