Strangest Brake Problem
Old 30 Dec 2008, 11:39 am
Default Strangest Brake Problem
My Cruiser brakes by its self at low speeds, I had it the garage today and they cant find any thing wrong with brakes, when he took it for a test drive he said it did it to him and hes never come across it before.
ANY IDEAS he also said the ABS light and traction control light came on ?????
Old 30 Dec 2008, 07:49 pm
Default Re: Strangest Brake Problem
Disconnect the negative battery terminal for 15 minutes to reset the computer and see if that helps. Also check to make sure the brake fluid is not low.
Old 01 Jan 2009, 05:04 pm
gave it a try and its made no diffrence, thanks any way.
Old 13 Apr 2009, 06:16 pm
try turning off the traction control. Other than that, brakes are pretty much mechanical so it takes an action to get a reaction. I can't imagine what would be compressing the hydraulics to make it brake.
Can you tell if it is front or rear.
Old 13 Apr 2009, 07:12 pm
A hung up caliper? Also, take fuse out for ABS - maybe controls went beserk?
Old 13 Apr 2009, 07:17 pm
Just a thought, are you sure it's the brakes being applied and not the transmission going into a lower gear which bring the car to almost a stop? Other that that, it's pretty much as Cal Cruzer says.
PROPPER USE OF THE EMERGENCY BRAKE GALVANIZEDYANKEE General PT Cruiser Discussions 0 23 Oct 2008 01:36 pm
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
Need some help with brake system Go_Cart_Racer Wheels, Tires, Suspension 5 26 Mar 2008 09:52 pm
Brake kits for the Pt Gt from Moparsupercenter.com JEFF@RHJEEP Vendors & Buyers Forum 0 23 Apr 2005 01:07 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
