| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
i just recently lowered my pt using the eibach pro kit. What i was wondering is if an alignment is 100% necessary. its been three weeks and it doesnt feel out of whack. Should i get one anyways? Second. Is an alignment kit going to be necessary for the 1.5 in. drop.
PTGT,
I, too, would recommend an alignment. It's cheap insurance to keep your tires healthy. An old Neon trick for camber adjustment is to elongate (not too much!) the clevis bolt hole in the strut. This free modification will give you more camber adjustment. Scott
\"If you choose not to decide, you still have made a choice.\" |
Definitely get an alignment. Tires aren't cheap. For my GT I didn't need a camber kit and for my wife's PT there was a need for the kit on only one side. You may need it or maybe not.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Gotta at least check before you do some real damage to the tires!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Just curious, since we're on the subject, is it necessary to get an alignment after a plus one, two or three increase in rim diameter/wheel size?
ED Lim,
The idea of a correct plus size is as the wheel gets bigger the tire and sidewall get smaller. This should not affect your alingment. As your overall tire/wheel size does not change.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge. Elbert Hubbard (1856 - 1915) 2003 Electric Blue GT- 30,000 Miles on the clock Stage 1, Mopar BOV, Brand X Air Box Pipe, K&N drop in, White silencer removed, Black lower silencer cut, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3 down pipe with high flow cat, BTG axel back exhaust, Rear Spoiler. Greddy Profec II B, Turbo Chargers Wastegate set to 13# Russel Brake Lines Hawk Brake Pads Power Slot Cyro Rotors Bag Stage II :-p |
LAF you are correct but I still get alignments after I buy new tires even if I dont change sizes! I think it is a good idea to start a new tire with it balanced and aligned ! With streets being maintained as they are and tires with low aspect ratios I think the front ends take a beating more now than ever before!
| I cant get an alignment with 20's goldline springs | ptcruz311 | Wheels, Tires, Suspension | 6 | 02 Aug 2006 05:28 pm |
| wheel alignment | onyx pt | Turbo Wheels/Suspension/Handling | 2 | 19 Aug 2005 09:10 pm |
| Lowering Kit and Alignment | CREWZIN | Wheels, Tires, Suspension | 13 | 11 Jan 2005 03:38 pm |
| camber alignment kit needed for front ??? | boosta | Turbo Wheels/Suspension/Handling | 7 | 10 Jun 2004 11:25 am |
| Alignment Kits | jramosGT | Tech & Performance Forum | 6 | 14 Jan 2003 12:47 pm |
