PT Cruiser Forum Car Videos
Car Rims
Rear Sway Mounts/Links
Old 01 Oct 2003, 12:38 am
onedivinehammer onedivinehammer is offline
Default Rear Sway Mounts/Links
I've noticed Eibach sells a kit (with mounts/links) for their rear sway bar. Anyone have any ideas on where I could purchase such? For some reason, Wykoff isn't selling the mounting links for the rear WITHOUT purchasing the rear bar. A bit akward ....
Old 01 Oct 2003, 12:56 am
Gear_Head Gear_Head is offline
Eibach supposedly has a kit that contains the parts needed, But I haven't seen it. Below is a list of the needed parts from chrysler along with the part#s. I think the total cost was $ 88.00. The links were $ 22.00 Each.
Below is the list of all of the parts needed for the install of the rear Sway bar on the GT Cruiser:
PT Cruiser GT Turbo
Parts List: Rear Sway Bar Parts needed for Aftermarket Rear Sway Bar (Yr.2003)
Part# Description QTY(ea.)
04656927AA---------RETAINER Sway Bar------------------------QTY-2
04656940AA---------RETAINER Sway Bar------------------------QTY-2
06504010-----------SCREW & WASHER Hex Head, M10x1.50x35-----QTY-2
04656934AB---------LINK Sway Eliminator---------------------QTY-2
06506496AA---------BOLT Lower Link to Sway Bar--------------QTY-2
06506509AA---------SCREW,Hex Head---------------------------QTY-2
06502696-----------NUT,Hex Flange Lock M10x1.5--------------QTY-4
The hex flange nut you do need 4 of. 2 extras for bolting the sway bar bushing bracket to the rail between the wheels.
Old 01 Oct 2003, 01:04 am
Thanks Alan!
I'll go to my dealership with these part numbers; much appreciated!
\'03 5-spd GT Turbo
Stage 1
AiRaid Intake System
Eibach Pro Kit Springs
Eibach Anti-Sway Kit
BTG Turbo Strut Bar
Ceramic brake pads
Mopar/Borla Dualies 2.5\"
Oh ... it\'s Onyx Green
Old 01 Oct 2003, 01:21 am
rice_killing_GT rice_killing_GT is offline
I went to my local dealership with those part #'s and they quoted me 120.00 and change for them. So I got them here http://www.ptcruiserlinks.com/pt/wy2.html for 76.00, received them in a few days. Price includes shipping.
When searching by part # (easiest method) don't add the 0 in the beginning.
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 01 Oct 2003, 09:18 pm
Larry Larry is offline
quote:Originally posted by rice_killing_GT
I went to my local dealership with those part #'s and they quoted me 120.00 and change for them. ....
Hmm. Chrysler list for these items is $76.60. Dealers get to charge whatever they want. Looks like your dealer was trying to make a big profit, and lost when you "walked".
Larry Hoy
2003 Black GT
Stage I Turbo Kit
Old 23 Oct 2003, 09:08 pm
PTGT Redman PTGT Redman is offline
Odered the Eibach sways.
Got the linkage parts from a local dealer.
Didn't have any of the parts in stock, so had to oder them.
Anyone know how to put together the linkage set and what the torque specs, etc. are?
If i put the car on ramps, can i mount the bar that way, or does the car need to be level?
Thanks.
Rob
Homepage:
Old 23 Oct 2003, 11:46 pm
PTGT Redman, When we installed mine we put it up in a lift. That was more for convenience than to keep the car level. I don't see any reason that they can't be done on ramps. The rear will be a PITA to get the nuts behind the flange on the twist axle and get the bolt started. I would recommend a 2nd person to help on the back to help hold the bar and get the nut behind the flange and get the bolt started. I taped the nut into an offset box end wrench to get it in behind and get the angle square enough to get the bolt started. On completion of the tightening had to encourage removal of the wrench with a hammer because as you tighten the bolt it draws the wrench into a position almost flat against the flange. Had to rap the wrench a couple of times to remove the wrench.
Here is a link to my post on the installation:
http://www.ptcruiserlinks.com/forum/...nti,ro ll,kit
Old 23 Oct 2003, 11:47 pm
macster macster is offline
Send a message via AIM to macster
Well
Check out my installation.
Macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 23 Oct 2003, 11:58 pm
Macster, Nice Pics What kind of shocks do you have, and how well do they work with the Eibach springs?
Old 24 Oct 2003, 12:17 am
Thanks
Koni's, is there anything else? The car handles completely different from the stock system. It doesn't float or handle like a boat. I love the way it tracks, basically it handles like a slot car. But to answer your question, they work very well with the springs, extremely well as a matter of fact.
macster
Don\'t help me
Help the bear
vB code is On
Rear sway bar kit turbomangt Turbo Wheels/Suspension/Handling 10 05 Jul 2005 12:40 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
  Vacation Spots | Mortgages | Cheap Flights | Car Insurance | Debt Management
