PT Cruiser Forum Car Videos
Custom Wheels
End Links front Sway Bar
Old 29 Oct 2003, 04:42 pm
PTGT Redman PTGT Redman is offline
Default End Links front Sway Bar
I'm installing my front Eibach Sway.
How tight should the end link bolt be tightened on the front Eibach sway bar?
It has a lock nut on the end, and I'm not sure if I tighten it until it is all the way tight or not.
HELP please.
Old 29 Oct 2003, 04:55 pm
Gear_Head Gear_Head is offline
Service manual states that those bolts through the rubber cushion should be torqued to 250 Inch pounds.
Exerpt from 2001-2004 PT Cruiser service manual:
(3) Clean the threads of the stabilizer bar link
bolts, then apply Mopart Lock And Seal or equivalent
to the threads.
(4) Install both stabilizer bar links back on vehicle
(Fig. 35). Start each stabilizer bar link bolt with
bushing from the bottom, through the stabilizer bar,
inner link bushings, lower control arm, and into the
upper retainer/nut and bushing (Fig. 1). Do not fully
tighten the link assemblies at this time.
(5) Lower the vehicle.
NOTE: It may be necessary to put the vehicle on a
platform hoist or alignment rack to gain access to
the stabilizer bar mounting bolts with the vehicle at
curb height.
(6) Tighten each stabilizer bar link by holding the
upper retainer/nut with a wrench and turning the
link bolt. Tighten each link bolt to a torque of 28
N·m (250 in. lbs.).
(7) Tighten the stabilizer bar cushion retainer
bolts to a torque of 28 N·m (250 in. lbs.).
Old 29 Oct 2003, 04:57 pm
Alan,
I got the retainer bolts set.
With regard to the endlinks, Eibach supplies a replacement set.
It has a lock nut that gets thread onto the bolt. The bushings are a little softer than the OEM ones. It seems as that I can tighten it a lot even after the bushings seat into the depression in the end of the bar. I just don't want to overtighten the links.
Homepage:
Old 29 Oct 2003, 05:02 pm
GTSteve GTSteve is offline
If you use a ft/lb torque wrench be sure to divide by 12. That means that 250 in/lb = 21 ft/lb.
Old 29 Oct 2003, 05:14 pm
I just went back to all of the instruction sheets that I could find from the kit (BTW I SAVE EVERYTHING) and could find no indication of any info that was read out as being different from the factory spec on the torque of the end link bolts. I used that spec (250 in/lbs or like steve said 21 ft/lbs) and after a few days I rechecked and retightened to that spec. On the retighten it was very minor........
Old 29 Oct 2003, 05:16 pm
Just got off the phone with Eibach. They said to tighten the end link bolt and nylock nut until the bushings are well seated and kinda bulged so they don't dislodge.
Homepage:
Old 29 Oct 2003, 05:25 pm
Thanks much, I'll have to recheck mine to insure that they're tight enough. Good Luck.......
Old 29 Oct 2003, 06:33 pm
took it for a ride, feels right.
Gonna put in the rear bar later tonight.
Homepage:
Old 29 Oct 2003, 07:06 pm
rice_killing_GT rice_killing_GT is offline
PTGT Redman, good luck with the rear bar. the nuts for the retaining clip are a real PITA, be ready to bend some tools.
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 29 Oct 2003, 11:59 pm
yeah, already ground down a wrench to 15mm and the cars on ramps now.
How tight do the endlinks that attach to the side of the wheel well have to be?
I have the torque specs on the other bolts. Also, the tabs on the bushing retainers should be bent, that may make it easier to install the retainers in that bracket. I'll let ya know
Homepage:
vB code is On
4 SALE - 26mm front sway bar Topless in Cali Classifieds: For Sale/Trade 7 16 Feb 2005 08:16 pm
Sway bar size front and rear AlmondTurbo Turbo Wheels/Suspension/Handling 0 28 Jun 2004 02:15 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Anyone look at their FRONT sway bar?? nbr10 General Turbo Discussions 3 06 Jul 2003 02:46 pm
  Tienda de libro | Payday Loan | Debt Consolidation | Electricity Suppliers | Remortgages
