Extened Studs for wheels
Old 17 Nov 2003, 09:19 pm
Default Extened Studs for wheels
Do you know if they make them
where to get them
how much [8)][?]
Old 17 Nov 2003, 10:56 pm
Send a message via AIM to macster
quote:Originally posted by Punch
why?
Punch
Good question,maybe he is going to run a dual wheel setup.
[:I]
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 17 Nov 2003, 10:59 pm
ESP101, check out my reply in the General Forums/Wheels, Tires, Suspension.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 19 Nov 2003, 08:17 pm
Chrysler uses a pressed in stud, you can buy them one by one at your local auto parts store or get them directly from Chrysler. To get longer studs (to use spacers or special wheels), I would guess that a simple eyeball measurement woud get what you want.
You can use a hammer to knock the old ones out, but if you are installing a whole set, it would be better to take your spindles to a machine shop and have them pressed out and replaced (still not all that expensive if you take the spindles in yourself.
Old 19 Nov 2003, 08:46 pm
There is a tool that is kind of like a pliers that tire shops use. YOu can just pop out the old one and use this device to press in the new one without taking the hub off.
Sheared Wheel Studs Batman General PT Cruiser Discussions 7 26 Aug 2010 08:35 pm
Replacing wheel studs KingKole02 Tech & Performance Forum 2 04 Feb 2007 04:28 pm
Extened Studs for wheels ESP101 Wheels, Tires, Suspension 1 17 Nov 2003 10:20 pm
