This rattle is driving me crazy! HELP!
Old 13 Dec 2003, 06:46 pm
Default This rattle is driving me crazy! HELP!
Does anyone who owns a 2003 or 2004 PT with an owner or dealer-installed rear swaybar have a rattle caused by the stock exhaust (hanger behind the muffler) hitting the left rear endlink? Any ideas to fix it (other than removing the rear swaybar)?? This is driving my wife and I nuts [xx(]....
I love the way the car handles now, but I fear railraod tracks, potholes, and my steep driveway [:0]
BTW, I have Progress swaybars (front and rear).
Thanks,
Scott
Old 13 Dec 2003, 07:00 pm
Wrap a piece of rubber around the hangar or the endlink, or both.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 13 Dec 2003, 10:30 pm
Scott you sure it's not the muffler hiting ? I know I had the same problem on my na when it was lowered.
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 13 Dec 2003, 11:25 pm
Send a message via AIM to macster
Ditto
Macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 14 Dec 2003, 11:45 am
I had a friend of mine put the car on a lift 3 weeks ago. You can see that the tip of the metal hangar hits the endlink when the exhaust is moved from side-to-side. We wrapped a piece of rubber fuel line on the endlink and zip tied it in place, however, the rattle and thunk is still there when it hits.
Does anyone have a cure? Different endlinks (offset?)?
Thanks,
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 14 Dec 2003, 10:49 pm
After i lowered my car, i could here a clunking. My source was where the pipe crossed the axle. I thought it was hitting the left watts linkage arm, but actually it was the pipe striking the frame of the car as it passed over the axle. When u lower it, there is a lot more suspension travel.
Homepage:
Old 19 Dec 2003, 10:49 pm
Thanks,
Scott
Electric Blue
Try this, Check the links for lose bolts, especially where the upper part of the link attaches to the frame. Check the bolts on the sway bar for tightness and security. Then take a piece of thick foam (to take up the space) between the end of the bump stop and the bump pad.
macster
Don\'t help me
Help the bear
Turbo PT and Winter Driving madcruiser Turbo Wheels/Suspension/Handling 3 04 Apr 2006 09:07 am
vibration causing dash to rattle Easymover Tech & Performance Forum 3 26 Jan 2006 07:34 pm
Driving styles by state... Gary04GT Non-PT Discussions 9 02 Dec 2003 11:27 pm
Rear seat belt rattle turbomangt General PT Cruiser Discussions 0 06 Oct 2003 09:57 am
Rattle in rear interior compartment! gtobey General PT Cruiser Discussions 6 30 Oct 2002 10:10 am
