Top Nut on Strut
Old 17 Dec 2003, 09:16 pm
LAF LAF is offline
Default Top Nut on Strut
I am gearing up for spring change and see there is a special tool for the top nut. I thought I saw something on a very easy solution to this. I searched but could not find it. Could someone help a old man out?
TIA
Old 17 Dec 2003, 09:51 pm
http://www.randgraphics.org/PT_Cruis...isc_photos.htm
surf about half way down the page....
Old 17 Dec 2003, 10:19 pm
LAF LAF is offline
Thanks Punch! Only one other question and that is what size spark plug socket, guess I will just try a couple.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Old 17 Dec 2003, 10:23 pm
Here's another option
http://tinyurl.com/37lje
Larry
2003 Black GT
Stage I Turbo Kit
Old 17 Dec 2003, 10:49 pm
The one I used (in the photo) was a 13/16th.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 18 Dec 2003, 12:08 am
LAF LAF is offline
IRPT,
Thank you for the info. Only one other question, you used your set up to only loosen the center nut before you removed the strut, correct? Then after using the sping compressor took it all the way off.
Old 18 Dec 2003, 12:11 am
LAF LAF is offline
Larry,
Thanks for the link. I dispise having to buy a tool for something that there is no need for. I know there are some times where it has to be, but a strut?
Anyway thanks......
Old 18 Dec 2003, 12:41 am
IRPT,
LAF, correct. Just loosen the center nut enough to allow you to turn it when you have the spring compressor in place and tightened down. You don't want the nut to pop off before you are ready, i.e. spring compressor in place and tightened down.
I used it again to tighten the nut after I had the strut assembly re-installed.
Mercedes Wiki
Strut Nut Problem with BTG Tower Brace purplept Turbo Wheels/Suspension/Handling 9 09 Jul 2004 08:06 pm
Strut Tower Bar and/or Anti-Sway Kit zzrogue Wheels, Tires, Suspension 4 04 Jul 2004 07:17 pm
January contest winners announced skylight General PT Cruiser Discussions 105 19 Feb 2004 02:39 am
Strut Tower Groan bigguigt Turbo Wheels/Suspension/Handling 20 15 Jan 2004 04:43 am
Koni Strut Question gooberff Turbo Wheels/Suspension/Handling 6 06 Oct 2003 07:41 pm
