So, since the weather got cold I have been meaning to check my tire pressure for a while now. I assumed the dealer who prepped me the car put in the correct pressure a couple months ago, and I knew I would be a little low. So, when I went around the car with the pressure gauge, I wasn't surprised to find the tires at about 29lbs. I figured between normal pressure loss and the cold, 3 lbs (from a standard 32) would be about right.
Imagine my surprise when I opened the dirver's door to find out the tires are supposed to have 38 PSI of air in them! Holy crap I have never seen a car demand that much pressure from the tires. However, I was noticing wear on the outside of the tire and the PT was handling like a boat (which I calked up to my lack of a rear sway bar). So now we'll see if life doesn't get better at 38 PSI. |
Never assume the dealer has done anything!
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
BTW, I run 42 psi in my tires, Nitto 455 225/17. macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
Huh? I thought we had a front sway but not a rear?
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
macster
We have a front. There's just no rear..mounting holes for it, but no rear. I put in a Eibach set and am pleased with the set up. Installed myself.
Makes a big difference.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
I run with 42 psi fronts and 38 psi rears with no rear sway bar and tire wear is very good! I do rotate about every 6,000 miles. I think you will find the ride a little stiffer but with less understeer!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
I also run 41-42 lbs. front and 38 lbs. rear.
Deen
GT, 5-Spd, K&N filter, Stage I, AGP 3147 Big Turbo, DTEC Fuel Kit, Tial WGA, Greddy Profec EBC, DCR 55mm TB, 05 Plastic Manifold, 180 Deg. Stat, CCA FMIC, AMX hard-pipes, Water-Injection, STS shifter, Needswings 3\" DP w/dump and Borla Cat-back, BG Drop Springs, Eibach Sway Bars, Panther alloys & Eagle F1 Max-Performance Tires. Best run to date...12.93 @113.45MPH. 77 Blown Vette-runs 10\'s @ 136 MPH. |
We have a front, just no rear, despit the factory window sticker,that says we do.
The higher pressure will keep the sidewall from rolling over as much, making handleing a little better. On my 89 caravan turbo, I had to replace the stock 205 70 15's, which had a lot of sidewall roll with 225 55 15 performance tires, with a stiffer sidewall design, and filled them to about 44 psi. Yes they fit, and only touch in one place inside the wheel well if I turn the wheel all the way, but only a very little. Anyway the van handles better than my moms stock focus ZX3 in the curves. It allso lowered it a little, which helped cneter of gravity.
88 Daytona Shelby Z T-II Blue 88 Daytona Shelby Z T-II Silver T-Tops 89 Caravan ES Turbo-I 03 PT GT Turbo 41TE Autostick Electric Blue |
| Holy Crap- Do you think this is a Stage 1!! | nuke72 | General Turbo Discussions | 2 | 27 Feb 2006 02:40 am |
| holy crap !! cleaning windows!! what to use?? | bobs turbo pt | The Detail Shop | 7 | 16 Sep 2005 09:33 am |
| Holy "FIRE" Batman | CREWZIN | General PT Cruiser Discussions | 2 | 11 Jun 2005 09:27 pm |
| Holy Crap! Did anyone see this... | CREWZIN | Non-PT Discussions | 8 | 29 Jun 2004 04:11 pm |
| Look at this PT glow (inside and out, HOLY #%$&) | alceryes | General PT Cruiser Discussions | 2 | 20 May 2004 11:08 am |
