Rob, I understand that but if you made a gasket from an innertube or something similar it wouldn't affect anything negatively . In all honesty I really think that since all of us don't experience the groan that it's something to do with the shock tower sheetmetal actually flexing with the addition of the strutbar. Especially since it's heard in the cabin as opposed to being felt in the steering wheel.
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Mean
Good point, why don't you guys compare the measurments of your strut bars? macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
It may be the sheet metal of you car. They are put together with + or - specs and you may be on the high or low end of it. I know my strut bar has slight rub marks in it from the two dimples of the heat shield on the under side of the hood. Right where the dimples for the washer outlets are. Called and talked with them and was told this was seen befor on a in house GT and no other reports. I asked if the bar could be off and was told no way. When you look at my hood to body gap it is very tight,others I have seen are loose. Not much to do for this problem. I suspect not much to do for yours either.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge. Elbert Hubbard (1856 - 1915) 2003 Electric Blue GT-30,000 Miles on the clock Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners Support Your Right to Arm Bears
macster
I've the same problem except even though al bolts are torqued to factory specs, I get more of a creaking noise form a complete stop
Any solutions yet?
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715 |
My BTG strut bar is waiting to be installed; I am having difficulty finding a torque wrench.
Sooo...we have various rubs and creaks....hmm...nicht gut. Is anyone having this problem with stock suspension? |
That could have something to do with the noises, what do you guys think?
Has anyone tried reving the engine at the throttle, hood open, to see what might be causing the noise. When I first installed my BTG Strut I noticed a "groan" metal against metal noise when coming to a stop and at the start of acceleration. When I popped the hood I noticed the strut was rubbing against the black metal throttle brace. The bar had a slight downward bow which gave zero clearence to the engines throttle brace. Seeing that this was a bad thing I removed the strut tower assembly, added six washers, one on each bolt to heighten the clearence, and slightly bent the strut bar from the center working outward until the slight downward bow became a slight upward bow. Replaced the strut bar as per BTG instructions, bolts torqued to 25lbs, wiped the fingerprints off the shiny new billet aluminum. It's been a day and I have not heard a peep from the Strut tower bar since. What was happening in my case and I suspect with many of you as well is, when the engine accelerates and decelerates the torque rocks the engine backwards and forwards; this is why the black throttle body brace has a 1 inch scratch and my strut tower bar has a 1/8th inch groove in it, hence the narly noise coming from under the hood. Hope this tid bit of info helps, and for me I can now take those corners 5 miles faster than before
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold. Mods On The Way: AGP Wastegate Actuator |
| Freedom Tower Strut bar | gonzomania | Wheels, Tires, Suspension | 18 | 04 Oct 2007 12:49 pm |
| Scuffing on top of BTG Strut Tower Brace | purplept | Turbo Wheels/Suspension/Handling | 5 | 20 Jul 2004 05:26 pm |
| Strut Nut Problem with BTG Tower Brace | purplept | Turbo Wheels/Suspension/Handling | 9 | 09 Jul 2004 08:06 pm |
| Strut Tower Bar and/or Anti-Sway Kit | zzrogue | Wheels, Tires, Suspension | 4 | 04 Jul 2004 07:17 pm |
| January contest winners announced | skylight | General PT Cruiser Discussions | 105 | 19 Feb 2004 02:39 am |
