Strut Tower Groan
Old 31 Dec 2003, 05:27 pm
Default Strut Tower Groan
Installed my BTG strut bar and noticed a distinct groan every time I took off from a complete stop. Took it home, reinstalled it (second time) and tried again. Same noise! I also noticed the strut bar was flexed in a U-shape with a 1/4" flex in the middle. (I measured it by putting a straight-edge on top of bar) I called BTG and they said the flex was normal and never heard of a "groan" complaint. I took off the bar and the groan was gone. I reinstalled the unit completely, (third time) and the noise came back. I left it on for a week, thinking that it might "settle in", but it continued. When I removed it the third and final time, the two tower braces were bent, the bolt brackets were scraped, and the strut bar had scraped off the paint from the metal housing that covers the throttle cables. My $200 BTG strut bar now sits on my workbench.[xx(] Been a fan of this forum since I've had my GT (February '03) but this is the first time I've needed to put in my two cents.
Old 31 Dec 2003, 05:38 pm
Send a message via AIM to Herschel
You might want to refer to "Dealer looked at
Groan" post. H.
Old 31 Dec 2003, 06:48 pm
bigguigt, welcome to the forum. As Herschel said, you aren't the only one. Here's the thread:
http://www.ptcruiserlinks.com/forum/...rchTerms=groan
2002 Inferno Red PT Limited
Mercedes Wiki
Old 31 Dec 2003, 08:31 pm
yet, i have this strut bar, one of the first made for the GT and have zero complaints with it, except the bolts are rusting....
Old 01 Jan 2004, 12:50 am
Sorry to see someone else having this problem with the BTG strut bar. The groan is still there. The funny thing is I can barely hear it when I first start up my GT, without moving. If I take the strut bar off the groan disappears. [:I]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 01 Jan 2004, 03:29 pm
I'm sure you did this, bu make sure the large bolts attaching your bar to the mounts are very tight. If there is play and the bar is shifting it defeats the purpose of the bar and will creak. Just a thought. I have no problems with the BTG bar.
Homepage:
Old 01 Jan 2004, 05:54 pm
thanks for responding.All the bolts were torqued to BTG specs.Does everybody have a bend in the strut bar itself?
Old 01 Jan 2004, 06:17 pm
What do you mean by "have a bend"? I don't have a bend, just the stupid groan. I'm calling PT Tuning on Friday to see if I can get an exchange for the defective bar I have now.
Old 01 Jan 2004, 06:34 pm
Just a thought....based on my own experiences with race and street strut bar and yours , contemplate this, don't you think it's possible this groan is nothing other than metal to metal contact? Why not make a rubber gasket and place it between shock tower and strut bar and see if the groan disappears or @least lessens .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 01 Jan 2004, 06:48 pm
There is zero space between the strut mounts and the bar to put the gasket, unless you use a liquid sealant.
Homepage:
Freedom Tower Strut bar gonzomania Wheels, Tires, Suspension 18 04 Oct 2007 12:49 pm
Scuffing on top of BTG Strut Tower Brace purplept Turbo Wheels/Suspension/Handling 5 20 Jul 2004 05:26 pm
Strut Nut Problem with BTG Tower Brace purplept Turbo Wheels/Suspension/Handling 9 09 Jul 2004 08:06 pm
Strut Tower Bar and/or Anti-Sway Kit zzrogue Wheels, Tires, Suspension 4 04 Jul 2004 07:17 pm
January contest winners announced skylight General PT Cruiser Discussions 105 19 Feb 2004 02:39 am
