..rear axle adjustment?
Old 02 Jan 2004, 03:05 am
Default ..rear axle adjustment?
..I recently lowered my GT with H & R springs, struts and shocks. This setup is the most fantastic improvement I have ever made to any vehicle at any cost! When I changed the wheels for more positive offset I noticed that the drivers side rear tire sits about a 1/4" further out from the body than the passenger side rear. When the suspension is lowered do we need to adjust the watts linkage? Car only has 3K miles and never wrecked, anyone notice this on theirs? Anyone think of an adjustment that might center the rear axle up with the body...I notice the watts linkage has two adjustment heims...I can't seem to find the correct procedure for this adjustment. Could somebody look in the factory manual and see if this indeed needs adjustment when our suspensions are modified...or just post what the actual adjustment for it is and how to do it for future reference.
Old 02 Jan 2004, 03:09 am
you should correct the camber...this may be why the wheel sits differently. Whether u correct for it or not really depends on how much you drop the car. rears can take a 2" drop without camber correction. Fronts I would do no matter how little i dropped it.
Homepage:
Old 03 Jan 2004, 07:59 pm
You are not going to get a camber change in the rear from lowering springs. It is a straight axle you would have to physically bend the axle to get a toe or camber change. In order to change camber or toe you need to remove the spindle an install shims.
rear toe adjustment rte662006 General PT Cruiser Discussions 8 26 Dec 2005 03:25 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Rear anti-sway bar install on GT JohnM General PT Cruiser Discussions 11 24 Jul 2003 07:38 pm
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
