Kosei K-1 Wheels with BFG Drag Radials Arrived
  #11 (permalink)
Old 10 Jan 2004, 02:19 pm
Send a message via AIM to Rolo
26" WHEELS, not RIMS, Saki. hehehe, lift kit on a PT, LOL! "Monster PT"
"USA-7/8" haha
"Big Footsie"
Okay I am done now.
  #12 (permalink)
I haqve the exact same tires and have not had a problem with boost cut. one thing I have noticed is that it isnt enough tire for the kind of hp I have I spin thru the 60 ft at a 1600 rpm = launch less than that and it will bog then spin the tires. I am thinking 225-50-15 DR or getting some halfshafts and some slicks I asked santa but he must have forgot!
  #13 (permalink)
Old 10 Jan 2004, 02:21 pm
"Son of Grave Digger"
OK, finished now.
  #14 (permalink)
Old 10 Jan 2004, 05:53 pm
Send a message via AIM to sakigt
"USA-7/8" haha
"Big Footsie"
Okay I am done now.
Duh. Drag radials are larger than low profile wheels so If I almost tuck my 18s on low profiles...whats the largest style rim I can fit. Me thinks 16....
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
  #15 (permalink)
Old 10 Jan 2004, 07:06 pm
sakigt, use this rim/tire caluclator to figure out what you need.
http://www.miata.net/garage/tirecalc.html
2002 Inferno Red PT Limited
Mercedes Wiki
  #16 (permalink)
Old 11 Jan 2004, 01:04 pm
Sweet link!
  #17 (permalink)
Old 11 Jan 2004, 05:10 pm
PVO PT:
It may have been my fault! Just discovered nos bottle heater had loose wire. Ergo I was probably the victim of a cutback because the wet system was dumping fuel without consistent flow of nitrous. System saw the super rich mix and cut back.
Running again today with the 15's and will report back later.
Frank
03 GT, Stage 1
Race Pipe and custom 3\" back, Eibach Springs, A Pods with EFT and Boost, MP Underdrive Pulley, 180 thermostat, Taylor Racing Wires, NX wet Nitrous 50 shot for quick spool/hp with msd tac drive and window switch, Mopar BOV, FIPK intake, APC Euro Tail Lite Kit, all badges removed.
  #18 (permalink)
Old 12 Jan 2004, 12:28 pm
how did you do frank??
  #19 (permalink)
Old 14 Jan 2004, 11:47 pm
It wasn't the wheels. It was the improperly heated NO2. Best run for the evening was 13.57 at 101.9 mph. Still had some pcm reset issues but now believe (thanks to 3BAR) was a bit too lean and knock sensor cut things back at the top end. Still working on the start and tire size. Starting to believe that with some 225 50 15s I can engage NOS mid-way through first (auto) and get close to the high 12's. With no rain this week - end I'll try again.
03 GT, Stage 1
  #20 (permalink)
Old 25 Jan 2004, 02:34 pm
Trying again this afternoon/evening. Just mounted some new BFG drag radials size 225/50/15 and should get lots more grab and will try to launch with NOS on. I'll report back tonight.
03 GT, Stage 1
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 15 12 Oct 2008 07:44 pm
Using bigger wheels lcuadrado Tech & Performance Forum 16 24 Jul 2007 01:06 pm
New best Autostick E.T. with Drag Radials blueberrygt Turbo Performance 5 14 Jun 2004 02:27 pm
SRT-4 Wheels on the GT blueberrygt Turbo Wheels/Suspension/Handling 3 13 Apr 2004 06:45 pm
Drag Radials/Slicks and 15" Wheels FRM3 Turbo Wheels/Suspension/Handling 2 16 Dec 2003 10:26 pm
