I have a stearing wheel that seems to vibrate a lot, especially from 60 to 70 mph. The alignment seem to be good. I can let go of the wheel and the car will track straight, no swerving. Any ideas or suggestions to voice to my dealer?
Thanks |
I had the same problem until I had the Rack & Pinion replaced for the "nylon rubbing sound". After the R&P replacement both problems went away.
![]() -------- 2003 Silver GT PT Cruiser 3rd Brk cling, APC GEN2 Eurotails. BTG Intake. StreetGlow Gold Series underglow kit \"Green\". BTG Strut tower Brace. |
You will also get a shake in the steering wheel if your front tires are out of balance. Might have that checked also. A shake at just some speeds is more likely to be tires than alignment.
2003 Almond GT AutoStick, body colored rear splash guards and hood struts, chrome gear shift, AC & vent knobs, billet steering wheel spokes and pedals, AMX1397 Turbo-Intake Pipe. |
Does your wheel shake when you apply the brakes? If so you probably have warped rotors. This can also cause the shakes at certain speeds if the warp is bad enough as the rotor rotates and comed in contact with the brake pads. Otherwise you may have thrown a wheel weight. HAve the balance checked out.
Good point Cal Cruzer. Warped rotors are a BIG problem with Ford vans and trucks. I haven't heard much about warped rotors on PT's but it is certainly a good thing to check. Usually, warped rotors start vibrating at 65 or 70 mph and as they get worse, the onset speed starts to lower somewhat.
I agree with nbr10, have your rack and pinion checked, this has been a problem on many PT's. If that's the problem it's covered by warranty.
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
shifted belt in tire!
you running stock rims?
If you have aftermarkets with spacers that can sometimes be a cause
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
My wheels did that after I hit a pothole and bent the rim [B)]
![]() 14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!! |
Thanks for all your input,
My car is going into the shop next week. I need to have some body work done, I have a nice big dent, busted tail light and wrecked bumber, some idiot pulled a hit and run. I also need to have the the oil filter mount replaced. I had an oil change done AT THE DEALER and the rookie doing the change, bent the fins on the filter holder and had oil leaking every where. I was able to help him seal the filter, but I now need a new set up. I am leaning towards the idea of having the tires rebalanced, but I will be sure to mention some of the other input you have given to me. Thanks to all
03 Electric Blue GT, chrome all over, k&n filter, smoke window guards, Harley Decals... |
| tarnished chrome wheel | mikehrz | The Detail Shop | 8 | 14 Feb 2005 10:49 pm |
| Mopar PT Wheel Lock Kit 82300160 | gtobey | Classifieds: For Sale/Trade | 0 | 24 Sep 2004 05:19 pm |
| Shaking Steering Wheel | GAHOO | Turbo Wheels/Suspension/Handling | 8 | 14 Jun 2004 11:22 pm |
| New Steering Wheel at Jegs | nhrapt | Interior Accessories Forum | 2 | 24 Feb 2004 01:03 am |
| Need help fixing a lug bolt. | KurtPT | Tech & Performance Forum | 4 | 12 Aug 2003 06:03 pm |
