Replace/install both sway bars or just rear?
Old 06 Feb 2004, 10:28 pm
Default Replace/install both sway bars or just rear?
I have what may be 2 stupid questions, but I've noticed that most of the discussions involving sway bars usually revolve around replacing both the front and rear (or installing a rear one for the first time for those of us with the "integral rear axle" sway bar) instead of just replacing/installing a rear sway bar.
What would be the disadvantages (handling-wise) of installing/upgrading only a rear sway bar (and leaving the front one stock)?
Any advantages to just installing/upgrading the rear (besides cost)?
Thanks,
Old 06 Feb 2004, 10:50 pm
im4gzs, check out this article, it has a good explanation of anti-sway bars. This should answer your question.
http://www.grmotorsports.com/swaybars.html
2002 Inferno Red PT Limited
Mercedes Wiki
Old 06 Feb 2004, 11:34 pm
just to replace the rusted front POS is reason enough to do both
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 07 Feb 2004, 12:21 am
if ur gonna put in an aftermarket rear, I'd do them both. Front one is ok, but is a rusted junk. Front install is actually easier to mount than the rear.
Homepage:
Old 07 Feb 2004, 02:31 pm
Thanks for the input, everyone. I don't like the rusty front stock sway bar, either!! Looks awful when I get under there to change my oil.
I read the well-written "inside scoop on anti-roll bars" that IRPT suggested and it indicated that if I leave the front sway bar as is and add a rear (and leave everything else the same), then I'll increase oversteer (the tendency to have the rear end be "loose" or to lose traction).
If I were to replace the front only with a bigger diameter bar than stock (and leave the rear sway-bar-less - which I'm not even considering, but I'm making an illustration), it'll increase the tendency to understeer (or "plow" through curves).
So, I can surmise that it's better to replace both sway bars at one time, because the effects of increasing understeer in front and oversteer in the rear will "cancel each other out," so to speak, and result in a overall better handling car than stock.
Guess I'll be asking for a set of front and rear sway bars for Valentine's Day (as opposed to just a new rear sway bar)! Now, I gotta decide what brand...I already have Eibach ProKit springs, so I'll probably go Eibach (part number 2860.320)...(and get the aftermarket rear sway bar installation hardware kit, of course, either from Eibach or Ma Mopar). Wyckoff has the MoPar/Eibach stuff here: http://store.yahoo.com/wyckoff-chrys...tcroemres.html
JC Moore, \'03 Cranberry GT, a.k.a. \"Zippy\"
http://www.mooresmopars.com/GT-Cruiser/index-gt.html
Stage1, BTG Strut Bar, Sun Hyperground system, Prototype Power CAI, no silencers, Eibach ProKit, Borla 2.5\" SSTL single w/dual tip, APC 2G Carbon Fiber Taillights, Chrome Fuel door, \'02 foldaway heated mirrors, OEM-style rear spoiler, Progress 22mm rear sway bar, TYC backup lights, Magnecor 8.5mm, stock plugs, MB Design \"Shifter\" 17x7.5 wheels, Goodyear Eagle F1 GS-D3 235/45/ZR17 tires
Old 08 Feb 2004, 11:21 pm
After further thought and discussion, since the stock front sway bar on my '03 GT turbo is about 26mm (according to my vernier calipers), then it's not going to do much good to replace the front with an Eibach 25mm swaybar and add a 22mm Eibach rear sway bar (since the Eibach front swaybar is smaller diameter than stock), so I've decided to get a Progress rear sway bar (also 22mm) and leave the front as is (and rusty as it is...), since I can't seem to buy an Eibach single sway bar (they always appear as a front/rear kit).
Old 08 Feb 2004, 11:34 pm
Bars may be made of different materials with different tensile strength. So a 26mm bar might not be stronger or torsionally more rigid than the 25mm bar.
I got the Eibach's and like them a lot. Gonna cap it off with a set of Koni adjustables.
Homepage:
Old 09 Feb 2004, 08:31 am
PTGT Redman, we did discuss the fact that the bars could be made of different material and thus that would affect the torsional strength/rigidity, but decided it wouldn't matter for my application, since I just want better handling for the street and I'm not tuning specifically for autocross or some other kind of competition.
Old 09 Feb 2004, 09:00 am
Why not remove the front, sand it and paint it.
I have Progress sway bars and painted both before installing.
Mercedes Wiki
Old 09 Feb 2004, 10:53 pm
IRPT, I am seriously thinking about painting that front sway bar; I think a nice turquoise might do! I still have some turquoise engine paint left over (I think) when we re-did the original 340 in my '69 Barracuda... http://www.mooresmopars.com/ModInterior.html
Shocks, Springs, Sway Bars Carchrism5 Wheels, Tires, Suspension 7 06 Dec 2005 09:32 pm
Sway bars quicksilverdon General PT Cruiser Discussions 11 12 Feb 2005 12:15 am
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
