Up size tire
Old 13 Feb 2004, 09:49 am
Default Up size tire
Goodyear dealer near me said that by going to a wider tire (215) I have to also lower the middle number (215-45-17) which I guess is the height ratio, has to do with clearence I guess. Does this make sense?
Old 13 Feb 2004, 10:31 am
Gary, yes that is correct, you want to keep your new tire size within plus or minus 3% of the OEM size in order to maintain correct odometer readings. Go to the links below and enter in different tire sizes, you will be able to see how they compare to the stock tire size. The first link gives you a visual representation or both front and side view of the differents between the two tires.
http://www.miata.net/garage/tirecalc.html
http://www.dakota-truck.net/TIRECALC/tirecalc.html
2002 Inferno Red PT Limited
Mercedes Wiki
Old 14 Feb 2004, 07:43 pm
another item to be aware of is that the various manufacturers can have different tire heights when compared to an identically numbered tire from someone else. i have been looking for replacements for the stock treads and am suprised at the amount of difference in the tire O.D. between manufacturers. a good source of info on this is www.tirerack.com. another source would be the various mfg. websites.
i have gone into tire stores and put a couple of choices side-by-side to make sure the O.D. is the same. am bummed that "blue scorchers" are not available in an O.D. that matches the stock treads..
redrum
03 GT
Old 14 Feb 2004, 10:08 pm
Send a message via AIM to macster
turbomangt
215 is not wider but taller. Now having said that, you can run 215/50's on the stock GT rim. Jody and a few others here have successfully done it.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 14 Feb 2004, 11:59 pm
turbomangt
macster
Actually the 215/50R17 is wider than the 205/50R17 by 10mm. It is also taller by 10mm x .5 = 5mm below the rim and 5mm above the rim. So the 205 is 8.07 inches wide with a sidewall height of 4.035 inches and an overall tire height of 25.07 inches while the 215 is 8.46 inches wide with a sidewall height of 4.23 inches and an overall tire height of 25.46 inches.
Going to a 215/45R17 would give the same 8.46 inch tire width but the sidewall height would be only 3.81 inches giving an overall tire height of 24.62 inches.
Old 15 Feb 2004, 02:50 am
Keep in mind that less sidewall height will also give you a somewhat harder ride (all else being equal) than a higher sidewall height! The key factor being that the sidewall deflection acts like a mini shock absorber!!
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
The BEST street tire in a 215/17 size CraigO Turbo Wheels/Suspension/Handling 13 16 Jul 2003 03:47 pm
tire size tom Tech & Performance Forum 3 16 Nov 2002 01:42 pm
