Brake Rotors
Old 15 Feb 2004, 10:13 pm
Default Brake Rotors
I see "drilled & slotted" brake rotors for sale on ebay, curious as to what drilled & slotted does for the rotor, operate cooler?
Old 15 Feb 2004, 10:35 pm
Found the answer to my question, slotted for better cooling.
Marty from MD
Black GT 03, BTG cat/back duals, rocket taillights, BTG shock strut bar, & Blane hood struts
Old 23 Feb 2004, 04:06 am
Not exactly right![:I] Slotted are better for gassing problems and therefore you get a better grip on the rotors. Drilled are used for gassing and heat problems. For strictly street use with stock rotor size you probably dont need either. Slotted looks kewl though Drilled have been know to cause stress cracks between the holes if not cast into the rotor. Kinda like pay your money make your choice[^] If you take a head count or vote more will vote for slotted over or drilled and drilled and slotted!!
Old 23 Feb 2004, 10:11 pm
SteelBlueGT, thanks for the reply, I think I will stick with the stock rotors and try and ceramic pads when the time comes.
Marty from MD
Old 23 Feb 2004, 11:43 pm
I hope that ceramic pads are available by that time. They are not currently available for the GT, only for the N/A PT.
Old 24 Feb 2004, 07:51 pm
I will probably get another 8 or 9 months out of the originals before I need to change them, hopefully by then ceramic will be available.
Marty from MD
Lomandi Brake Pads and Rotors CHROMEDCRUISER Wheels, Tires, Suspension 5 24 Feb 2010 06:29 pm
Disc Brake Pads and Rotors . Rich Slider Tech & Performance Forum 18 13 Jan 2006 04:27 pm
Brake kits for the Pt Gt from Moparsupercenter.com JEFF@RHJEEP Vendors & Buyers Forum 0 23 Apr 2005 01:07 pm
Brake Rotors Hooligan Wheels, Tires, Suspension 9 29 Aug 2004 09:07 pm
Factory brake rotors cracking already (under 30k) braindead0 Tech & Performance Forum 6 30 Sep 2003 04:38 pm
