Lowering with roll pan
Old 24 Feb 2004, 11:00 am
Default Lowering with roll pan
What adjustment needs to be made if you lower the car with repsect to a roll pan and exhuast. the exhuast has 1/2" clearance now with the roll pan, lowering 1 1/2" will cause the pipes to butt up against the roll pan. ??? [:I]
Old 24 Feb 2004, 12:06 pm
It shouldn't cause the exhaust is mounted to the underside of the car. It may change the angle of the pipes relative to the ground and bring them a hell of a lot closer.
The pitch of the pipes you can probably adjust.
More concerning is clearance of the pipe as it passes over the rear axle and it's relation to the left arm of the Watt's linkage.
That you lose a lot of clearance on whenyou drop the car.
BEFORE
AFTER LOWERING. YOu can see the change in agnle of the pipes.
Homepage:
Old 25 Feb 2004, 01:24 am
I see, I wonder if this will present a problem in regard to install? I guess the place I should start would be PT Tuning, since I have the BTG exhaust, and ask how the springs work together with what I have.
Old 25 Feb 2004, 01:48 am
That'd be a good idea. They stand behind there products.
Homepage:
Old 25 Feb 2004, 09:06 am
Send a message via AIM to sakigt
Well, Im dropped 3 inches in the rear with a rollpan and the stock exhaust holds up fine...Unless you have to drive 6 New Years partiers over a speed bump, then you scrape the muffler
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 25 Feb 2004, 09:47 am
Saki,
stock system works fine. If you go wider tho, how the pipe clears the rear axle is important. With new springs there is more suspension travel and contact with suspension components is more common. Granted if the car is lowered when you put the exhaust on, you can prolly adjust the pipe around the axle.
I had this problem with my Borla on my 01 and with the Bassani on my 03. You'll find peeps with no probs, this is just my experience.
Homepage:
roll pans? elvisjer Exterior Accessories Forum 10 26 Apr 2007 09:52 pm
Lowering springs only on the back??? gtbright General Turbo Discussions 2 22 Nov 2004 11:14 pm
Before installing lowering springs... Gary04GT Wheels, Tires, Suspension 14 18 Jul 2004 08:57 pm
Roll Pans Gunner Exterior & Interior Styling 2 03 Jun 2004 10:35 pm
Lowering Kits ptturbo Turbo Wheels/Suspension/Handling 3 08 Nov 2003 10:24 am
