| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Cal Cruiser - I agree with your handling analysis. I was prepared for the possiblity of more understeer with the addition of the [stock]rear bar and was pleasantly surprised that it is not an issue - like you say at 8 or 9/10's. I feel that with the rear bar, the handling is improved so much that you can push the car to the tires limits comfortably, whereas before the suspension was mushy on turn in and reduced predictability as to the limits.
Others will, and have, disagreed on the theory of more rear roll stiffness creating a bias toward understeer, but that's what makes the world go round. JohnM |
Okay, I'm not ashamed to admit that this whole suspension thing has me confused as can be. So on my 03 GT I have the eiabach sport springs and I just orderd a set of Koni's now if I were to order the Eiabach sway bar kit say from Wycoff what else would I need for the sway bar kit to install? Also what setting on the Koni's? Don't want to firm on this daily driver..
Thanks! [8)]
http://www.imagestation.com/album/?id=4290145623 It\'s gone but not forgotten. Still love the Cruiser but my heart got stolen buy a Ruby Red 05 Legacy GT! |
I would start out on the softest setting and see if that is OK for the shocks and struts. If you feel you can handle more stiffness tighten em up to next level and so on. In my youth I would start at the other extreeme and hardly ever change. Two things happened over the years, my tolerance for pain decreased and the new technologies made stiff very stiff.
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
A friend and I installed rear swaybars on our GT's. Instead of using the oem bolt that holds the bar to the rear axle, use a 2" long stud, 3/8 dia.( its about .020 smaller the the oem bolt) and put the back nut on the stud and then inserting the bolt thru the bushing bracket and then put the outside nut on. Works slick, and if you have a hard time holding the nut inside the bracket that hold the assembly to the axle, the 2" in stud is long enough to put a pair of vice grips on the tip of the stud to hold while tighting the nut.
Hey MCRUZ, if you don't understand what I meam, let me know, will try to explain better. This approach make it easy to install the bar, because you don't have to fight the hidden nut, which has been the big bugabo on putting the bar on the "03's and '04's. This makes the 3rd bar(oem)I have installed on the PT's, got smart after the first.
Has anyone been able to bet the clamshell bottom into that little slot it's supposed to be in? I couldn't get mine in there and still start the bolt. If I use a stud like this I should be able to. Thanks.
The bar retiner bolt is tough to work on, but do-able...just takes time to tighten it down. Issue is when the bolt is tightened down, keeping a wrench on the nut becomes a problem.
I've had my Eibach's on with the stock endlink setup for a few months and love the difference. Koni's are in the future once the Tokico stocks burn out.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
Thanks Guys! Haven't been on in awhile so it's great to know you all are still out there!
[8D]
I've heard the same thing about guys having trouble getting the bracket into the slot, I must have been lucky, because all of mine went in fine. Might help to put the two pieces together and flatten the bottom of bracket with a few hits with a hammer on a vice or such.
Chrysler is nuts when they say that the addition of a rear swaybar is dangerous, I think it should be the other way around! Did you know when you order the rear bar mounting parts it directs the parts guy to a TSB 02-004-02 through a global parts order processing service repair tips document, crazy [:0]! If you do not install the bracket in the slot you are going to bend and break the brackets and the bar is not going to work like it should either! I did not have any problem with the bracket. I installed the brackets into the slot with the forward bracket flipped down and then slid the bar/bushing in. I used a needle nose vise grip and clamped it closed. I just used a open end wrench to hold the nut behind the mounting bracket and just lined up the hole in the bracket with the nut. Took about 1 1/2 hour to install the front and rear bars. It is very important that you tighten everything up when the vehicles weight is resting on the suspension! I have to admit, it is a lot easier when you have a lift and alignment rack at your disposal ! |
| Installed my rear Door sills | gonzomania | Interior Accessories Forum | 9 | 28 Dec 2004 07:00 pm |
| Installed Eibach Anti Roll Kit(Front & Rear Sway) | Gear_Head | Turbo Wheels/Suspension/Handling | 27 | 28 May 2004 02:05 am |
| Installed OEM Rear Sway Bar | silky | Turbo Wheels/Suspension/Handling | 20 | 22 Mar 2004 05:00 pm |
| Rear Swaybar parts & mounting help please | Cal Cruzer | General Turbo Discussions | 5 | 22 Jan 2004 05:24 pm |
| Installed rear bumper step-pad (kinda long) | PTRON | Exterior Accessories Forum | 0 | 17 Feb 2003 12:50 pm |
