??WILL THESE FIT??
Old 18 Mar 2004, 04:25 pm
Default ??WILL THESE FIT??
I WANT TO BUY AKUZA SUBLIME RIMS THEY ARE VERY NICE THE DIMENSIONARE 18 INCH BY 7.5 ON A 42 MM OFFEST. IS THE OFFSET TO MUCH AND WILL IT MAKE THE WHEEL STICK OUT? GIVE ME UR OPION.
http://www.coolwheels.com/product_di...oduct_id=10365
Old 18 Mar 2004, 09:07 pm
I didn't see any 18 x 7.5 rims of this style listed on the site, they had a 17 x 7.5, 18 x 8.5 and 19 x 8.5. Did not see the bolt pattern listed either. The recommended offset for the N/A PT is 35mm to 42mm, bolt pattern 5x100. Many people run offsets that differ from those mentioned above, you must also consider the backspacing.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 18 Mar 2004, 09:22 pm
Nice rims.
They should fit. Just make sure the hub fitment is right so the weight of the wheel is not only on the lugs.
My Ronals are 42mm and fit just right.
Homepage:
Old 18 Mar 2004, 10:44 pm
So yours are 42mm and you don't use any kind of spacer on them? I was considering some nice 18x7.5 with a 40mm and was curious if they would be 'in' too far.Yours look nice.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 19 Mar 2004, 01:36 am
Yeah, the Ronals come in various offsets. I think they just shift the point on the rim face where the spokes connect. The seem as wide as my Mille's which were 8" rims but these are only 7.5
Soon as the friggin snow goes away i'll remount them and take an edge on shot.
Homepage:
